error compilation
RLOPES780
Been thanked: 3 times
error compilation
Post by RLOPES780 »
Target folder: C:\Users\RICARDO\Desktop\DEFINITIVO
Source name: C:\Users\RICARDO\Desktop\DEFINITIVO\DEFINITIVO.fcfx
Device: PIC16.33E.33EP512MU810
Generated by: Flowcode v7.3.0.5
Date: Tuesday, March 24, 2020 11:16:47
Registered to: RLOPES780
Licence key: 11X4UJ
http://www.flowcode.co.uk
Iniciando o compilador …
C:\Program Files\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat "DEFINITIVO" "C:\Users\RICARDO\Desktop\DEFINITIVO\" "33EP512MU810"
Launching compiler...
Options have been disabled due to restricted license
Visit http://www.microchip.com/ to purchase a new key.
coff-cc1.exe: fatal error: DEFINITIVO.c: Permission denied
compilation terminated.
Error returned from [xc16-gcc.exe]
C:\Program Files\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat reportar código de erro 1
RLOPES780
Re: error compilation
Post by RLOPES780 »
file
DEFINITIVO.fcfx
(12.01 KiB) Downloaded 314 times
It's compiling fine for me here in v7. Have you edited your compiler options at all?
Check the Build -> Compiler Options menu that the default item is selected as the default compiler for your device family.
This may be related?
https://www.microchip.com/forums/m1028254.aspx
RLOPES780
Post by RLOPES780 »
Hello Benj;
Grateful for the answer.
The error resolved.
I had the iobit malware fighter installed on my computer.
It looks like it was causing the problem. It solved without it. Could that be it?
Thankful;
Ricardo.
"Title:
Description:
Date: Sunday, March 29, 2020 12:15:59
Users: 1
Licence key: 11X4UJ
Compilation successful!
Completed compilation, return = 0
Iniciando o linker/assembler…
xc16-ld 1.26 (A)
Program Memory [Origin = 0x200, Length = 0x55600]
section address length (PC units) length (bytes) (dec)
.text 0x200 0x120 0x1b0 (432)
.const 0x320 0x16 0x21 (33)
.text 0x336 0x79e 0xb6d (2925)
.dinit 0xad4 0xe 0x15 (21)
Total program memory used (bytes): 0xd53 (3411) <1%
Auxflash Memory [Origin = 0x7fc000, Length = 0x3ffa]
Total auxflash memory used (bytes): 0 (0) <1%
Data Memory [Origin = 0x1000, Length = 0xd000]
section address alignment gaps total length (dec)
.nbss 0x1000 0 0x2 (2)
.bss 0x1002 0 0x14 (20)
Total data memory used (bytes): 0x16 (22) <1%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0x1016 0x6fea (28650)
Maximum dynamic memory (bytes): 0x6fea (28650)
Generating HEX file
Generating Assembler file
HEX file creation successful!"
RLOPES780
Post by RLOPES780 »
Hello Benj;
Seizing the occasion.
There is an old project that was stopped and I went back to work. As I formatted the computer it is giving an error at the time of compilation presenting the following message "sor 'is out of range. Suggest large-code model". large-code and explain where I put it. I'm using flowcode 7, but you can also send me to flowcode 6 if I need to.
Thankful;
Ricardo
Hello Ricardo,
To switch to the large code model we have an alternative compiler batch file you can point to. The large code model uses more ROM/RAM memory by extending pointers etc but allows you to use the entire memory on larger MCU devices.
Use the Build -> Compiler options menu and create a new save based on the 16-bit PIC defaults by clicking the save icon and entering a name.
Next change the Compiler location to the following.
$(appdir)compilers\pic16\batchfiles\pic16_C30_compLarge.bat
Change the linker location to the following.
$(appdir)compilers\pic16\batchfiles\pic16_C30_linkLarge.bat
Ensure that the default checkbox is checked and you should be good to go using the large code model. If you need to switch back then simply re-select the default option as the default using the checkbox.
Let us know how you get on.
