how to install flowcode v8?
RLOPES780
Been thanked: 3 times
Post by RLOPES780 »
I installed FlowcodeV8_Installer.msi and everything was ok. When I install FlowcodeV8.2_Patch.msp and FlowcodeV8.2.2.15_Hotfix.msp I have the following message "the update patch cannot be installed by the windows installer service because the program to be updated may be missing"
Thankful;
Ricardo.
Re: how to install flowcode v8?
Hi Ricardo,
I believe if you have downloaded and installed the full version then the patch and hotfix are not required. These are for earlier versions to bring you up to date.
RLOPES780
Post by RLOPES780 »
Hello Benj thanks;
Understand.
The version I'm using is in English, can't you configure it for Portuguese for example?
I ran a small test program attached below and got this message from the compiler "PIC16 toolchain is not instaled"
Thankful;
Ricardo.
DEFINITIVO.fcfx
(12.01 KiB) Downloaded 202 times
Hello Ricardo,
The toolchains can be downloaded and installed from here.
https://www.matrixtsl.com/flowcode/download/
We no longer ship the toolchains with the main Flowcode installation as not everyone wants all the compilers and it made the main installation very large.
The language can be changed in the View -> Global Options -> Application tab.
Though it looks like we don't currently support Portuguese as a native language.
