Hi all
I have a simple question:
In my proyct have 3 buttom, the first buttom is connect to porta1, the second buttom connect to porta2, and the third buttom connect to porta1 and porta2 in wired mode with two diode, in simulation mode i don't have a problem for buttom1 and buttom2 but for buttom3 ?.... is it possible push buttom1 and buttom2 in same time or programmed buttom3 in wired and mode for tested?
thanks
best regards
wired and buttom simulation
- Has thanked: 187 times
- Been thanked: 205 times
Re: wired and buttom simulation
I have had similar needs.
FC allows you to assign keymappings whereby you can assign functions to the keyboard. In the attached example I have outputs on A0 and A1 and inputs on B0 and B1
In the example the program loops reading the value of Port B and outputting to Port A. If I click B0 then A0 will illuminate etc and under keymappings (right click on a button) you can see I have also assigned keyboard keys 1 and 2. If I press "1" then A0 illuminates etc.
Keymappings also allows you to create a calculation and you can see that if I press key "3" then I assign a value of 3 to variable "input". However although FC allows this I have never really got it to work well (probably my fault by doing something dumb) unless I have the simulation speed incredibly slow and even then it is very hit and miss. It does actually work but way, way too unreliable.
Instead, if I have a spare port I assign that as a test input. In the example I have used B2. When I read / test for an input and it corresponds to my test port, I then assign a predefined value to my input variable(s). In this case if I press B2 it assigns the value of 3 to "input" which then illuminates A0 and A1 mimicking pressing B0 and B1 simultaneously. I have also keymapped "4" to do the same.
I'm sure someone far cleverer than I will have a better way to do this but this has worked for me during testing.
- Flowcode1.fcfx
- (12.68 KiB) Downloaded 171 times
Following on, maybe the attached can give you some ideas?
The most consistent way I can find to simulate two push buttons pressed simultaneously is to loop until the variable assigned to the buttons is greater than zero (in my example it is "x"). The program then breaks away to do whatever.
Whilst it doesn't catch every press of Key "3", looping until one of the options occurs does catch it enough times to be of use. I've never had to press "3" more than a few times to be caught.
I appreciate that in real world you may not wish this but for simulation it may help.
You will see I have buttons on ports A0 and A1. When pressed they illuminate LEDs on C0 and C1 respectively. I have also keymapped keys "1" and "2" to A0 and A1. I then Keymapped a calculation to Key "3" which sets "x = 3".
Hope it helps.
Hope it helps.
- Button Test.fcfx
- (12.85 KiB) Downloaded 152 times
