USBasp-Compiler Options not correct
zwilling77
Been thanked: 2 times
Post by zwilling77 »
I get the error message Error returned from [avrdude]...Think that here the paths in the compiler options from the programmer are not correct. Can someone tell me where the error is? I´m using USBasp for programming AVR ATXMega256A3Bu...Thanks
Compiler Options:
$(appdir)compilers\avr\batchfiles\avrc_asp.bat
Parameters:
%a usbasp usb "%f.hex" %cfg %c0 %c1 %c2 %c3
Compiler Message:
Launching the programmer...
C:\Program Files (x86)\Flowcode v8\compilers\avr\batchfiles\avrc_asp.bat %a usbasp usb "%f.hex" %cfg %c0 %c1 %c2 %c3
C:\Users\ogoetz\DOCUME~1\Flowcode>"C:\PROGRA~2\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\AVRDUDEusb\avrdude.exe" -p usbasp -P usb -c usbasp -U flash:w:%cfg
Das System kann den angegebenen Pfad nicht finden.
C:\Program Files (x86)\Flowcode v8\compilers\avr\batchfiles\avrc_asp.bat reported error code 1
Re: USBasp-Compiler Options not correct
Does the AVRDUDEusb folder exist on your system?
Can you try avrc.bat instead of the avrc_asp.bat. Looks like the latter is no longer required.
zwilling77
Hello Ben,
thankx for the fast answer! I have now made the change and now comes the following error messages...
C:\Program Files (x86)\Flowcode v8\compilers\avr\batchfiles\avrc.bat %a usbasp usb "%f.hex" %cfg %c0 %c1 %c2 %c3
C:\Users\ogoetz\DOCUME~1\Flowcode>"C:\PROGRA~2\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avrdude.exe" -p usbasp -P usb -c avrispmkii -U flash:w:%cfg
avrdude.exe: AVR Part "usbasp" not found.
Valid parts are:
uc3a0512 = AT32UC3A0512
c128 = AT90CAN128
c32 = AT90CAN32
c64 = AT90CAN64
pwm2 = AT90PWM2
pwm2b = AT90PWM2B
pwm3 = AT90PWM3
and so on
C:\Program Files (x86)\Flowcode v8\compilers\avr\batchfiles\avrc.bat reported error code 1
zwilling77
Hello Benj,
can you help me to fix the configuration problems,please...
The avrdude runs with arduino,but I need the usbasp for programming.
Here's a new version of the avrc_asp.bat file, looks like there are some subtle differences in this compared to the standard avrc file.
avrc_asp.bat
(1.52 KiB) Downloaded 281 times
Copy this over the file here.
C:\Program Files (x86)\Flowcode\Common\Compilers\avr\batchfiles
In the compiler options the programmer should be set to
$(compileravr)batchfiles\avrc_asp.bat
And I beleive the parameters should be
AVRDUDE $(chipalt) $(chip:l) "$(outdir)$(target).hex" "$(target).hex" 0 $(cfgb) $(cfg0) $(cfg1) $(cfg2) $(cfg3)
Let us know how you get on.
zwilling77
Hello Ben,
the next failure massege is...
avrdude.exe: error: programm enable: target doesn't answer. 1
avrdude.exe: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude.exe done. Thank you.
C:\Program Files (x86)\Flowcode\Compilers\avr\batchfiles\avrc_asp.bat reported error code 1
FINISHED
celebriums
Has thanked: 71 times
Been thanked: 33 times
Post by celebriums »
Dear Matrixmultimedia Family Warm greetings from Istanbul
Thanks Benj
avrc_asp.bat file very fine works. :D
-I have a question?
Can calibration values be added here?
https://www.avrfreaks.net/forum/atmega8 ... -byte-8mhz
~$ avrdude -p atmega8 -t
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.07s
avrdude: Device signature = 0x1e9307
avrdude> dump calibration
>>> dump calibration
0000  89 41 5a 3c                                       |.AZ<            |
avrdude>
Note:
Not LowFuse, HighFuse, or Extendet fuse. Because the calibration settings don't work on ExtremeBurner.
I've been doing research for five days.
I've read that only Atmel ICE, AVRISP MKII, or JTAG ICE programmers can do calibration values. Obviously, this is ridiculous, and I think the USBASP programmer can do it.
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x1e9307
avrdude.exe: NOTE: "flash" memory has been specified, an erase cycle will be performed
             To disable this feature, specify the -D option.
avrdude.exe: erasing chip
avrdude.exe: reading input file "atmega8aforAtmelStudio.hex"
avrdude.exe: input file atmega8aforAtmelStudio.hex auto detected as Intel Hex
avrdude.exe: writing flash (176 bytes):
Writing |
################# | 100% 0.21s
avrdude.exe: 176 bytes of flash written
avrdude.exe: verifying flash memory against atmega8aforAtmelStudio.hex:
avrdude.exe: load data flash data from input file atmega8aforAtmelStudio.hex:
avrdude.exe: input file atmega8aforAtmelStudio.hex contains 176 bytes
avrdude.exe: reading on-chip flash data:
Reading | ################################################## | 100% 0.10s
avrdude.exe: verifying ...
avrdude.exe: 176 bytes of flash verified
Programming successful!
FINISHED
Sincerely Regards
Sadık SUME
www.kaandesign.com.tr
