Easter Special
- Has thanked: 9 times
- Been thanked: 3 times
Easter Special
Hello I am from Germany and use Flowcode 6, because Flowcode 8 is currently being offered for an Easter special, I would like to upgrade or purchase a new license, I will only be redirected to a page where I can not make a selection, where exactly I can choose and buy?
I actually thought when I logged into my Matrix account that I could purchase a new license there, but I would only ever be forwarded to the same page......
Thank you in advance
- Has thanked: 187 times
- Been thanked: 205 times
Re: Easter Special
I don't think I've ever successfully ordered anything "online" without issue. I usually have to email "sales" or call. As an example if I login I can see all my licences but if I want to add anything, say a feature pack, it forces me to add in a copy of Flowcode too.....
However in fairness to Matrix they have always honoured special offers if I can't process "online" in time
Re: Easter Special
Hi chipfryer27,
thanks for your comment, I thought it was just me, most of the time with both programs F6 / F8 I had previously spent buying and adjusting the compiler options .... not programming
So far I haven't made F8 "run" ...
Have a good time.
Have a good time.
Re: Easter Special
ok i managed to program my Attiny84A with Flowcode 8, now I would like to know why I need ca.8000 bytes flash for F6 and less than half with F8 with the same program
Re: Easter Special
I'm sure someone with far greater knowledge will answer with the correct reason, but I "suspect" it is to do with the compiler. FC6 uses "BoostC" whereas FC8 uses "xc8".
- Has thanked: 553 times
- Been thanked: 1081 times
Re: Easter Special
For Atmel controllers FC6 didn’t use BoostC as that is for 8 bit pic controllers only. FC8 does not use xc8 either.
Given the lack of information regarding the flowchart used I don’t think anyone can provide any useful feedback.
― C.S. Lewis
― C.S. Lewis
Re: Easter Special
Hi Kersing
I bow as always to your superior knowledge
I did state I "suspect" that was the reason. However I use PIC and according to FC8 I am indeed using "xc8" but concede that other targets don't.
Re: Easter Special
I am happy to give more information!
I have built an extension for an awning remote control because I want it to retract when the wind gets too strong.
So there is an Attiny84A installed which can output the time / date via I2C with an RTC3232 and an accelerometer which monitors the movement of the awning via ADC.
If I have the program converted from F6 to C and then load it back into Attiny84A with Atmel Studio, then I also get about half the bytes that are also read in at F8!
Would be happy to hear from someone again
greetings
greetings
Re: Easter Special
Posting a flowchart would help. That allows us to see what is being used and build it ourselves to check where usage may be.
― C.S. Lewis
― C.S. Lewis
Re: Easter Special
For that there has to be a basic answer, something like chipfryer27 had suspected, I can't imagine that it has anything to do with the flowchart, as I said, without modification with F8, only half the bytes are compiled!
I think that too many or larger libraries are involved in F6.
Thanks anyway
Thanks anyway
Re: Easter Special
Hi, I think I have now roughly figured out why there was a big difference in bytes when compiling.
I had components in Project Explorer that were not included in the program, F6 converted the associated libraries / components into code anyway, which F8 did not do, after I deleted the unused components, the compiled bytes were roughly the same for both programs !
I would now like to be interested in the background why this is handled so differently, I would like to pass this question on to Benj, Benj, if you read that, I would be happy to hear from you!
Happy Easter
Happy Easter
Re: Easter Special
If I understand correctly you want to know why FC8 creates more efficient code? Normally people want to know the why when code becomes less efficient, not when it becomes more efficient...
― C.S. Lewis
― C.S. Lewis
Re: Easter Special
Hi Kersing, yes, that's exactly the way it is, because it would make the decision for me whether I buy F8 or not! If I knew exactly that you can't do better in F6, I would definitely buy F8, right now because of the 50%!
Sure, you just delete things you don't need, but still have to test the difference if I only ever use part of a component .....
In addition, you are always interested in the things you are dealing with and the more background knowledge you have the better .... for me.
Re: Easter Special
For AVR devices we found that the GCC compiler did not by default remove unused functions and code from your compiled hex file. Lots of arguments around this on the AVR geeks website which I won't go into. On discovering this we changed our compilation and linking scripts to force the compilers hand and removed any unused code and variables. I beleive this was either late on in v6 development or for v7.
Re: Easter Special
..... when using components in F8, only the part of the component that you have included in your program is really used, that's great! The one component listed in the Project Explorer that is not being used is not compiled, I now knew, I just wanted to know whether the entire component was compiled when integrating small parts.
Still decided to stay with F6, wait for an upgrade offer
Nice week to everyone
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Easter Special
There is already an offer for upgrading v6 to v8 - you get 30% off. This current Easter offer improves this by providing an extra 50% off.Xbeejunior wrote:Still decided to stay with F6, wait for an upgrade offer![]()
As a quick example, if the v8 licence you want is £500, as a v6 user you would get it for £350 normally (30% discount). At the moment, you get 50% off that – so the final purchase price would be just £175.
Although the offer does end soon...
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: Easter Special
You can only have Flowcode related products in your basket for it to process, if you still cannot use the code, please let me know what the error message you are getting is and a screenshot of the issue occuring if possible, we have had a lot of people use the code over this last week so hopefully its something simple to fix.
Re: Easter Special
Hi DavidA, the code would have been accepted without logging in, but then I would have had to take a new license, but I didn't want to, so I thought the code could not be used for an upgrade!
But when I read the message from Steve I think it should have gone with registration?
Now the time has run out, but on the picture you can see how it was this morning ...
- (95.2 KiB) Downloaded 592 times
Re: Easter Special
Good morning, ok that's great, also that so many answered me, only now I still don't know if the 50% would go for my upgrade from F6 to F8 as Steve answered me, which will be in the shopping basket the code FC50OFF not accepted after I logged in with my account! I'd call Sales, but it will be difficult with my English
- DavidA
Re: Easter Special
Sorry for the issues you are having, can i ask which country you are trying to buy from?
Re: Easter Special
if I went through the ElektorUK website then I came to the shopping cart, but the code is not accepted because I have to order via matrixtsl.com, via Matrixtsl.com I only ever got to, see attached picture, and never to the shopping cart !?
In any case, I have now clarified this by email, thank you Liam for the quick processing!
- (143.09 KiB) Downloaded 533 times
Re: Easter Special
I would like to know if the special offer is always extended ?Steve wrote:Our special offer has been extended, so there's still time to upgrade.
Windows 10.0.18362.778
Flowcode v8.2.2.15 (2020-02-28)
