Hello Forum Members,
I am trying to edit some code published by Medelc35 and am having difficulty in working out what to do.
Bear with me as my programming knowledge is very limited.
I want to test 4 individual bits in a variable and carry out some action based on their individual values.
I have tried the decision block as found on another forum page but still without success.
If anyone can help me resolve how to do this I would be most greatfull.
Thanks in advance.
Richard Hogan.
Reading Individual variable bits.
Re: Reading Individual variable bits.
Hi Richard,
This is what I do to test for bits:
or
So if you want to see if bit 2 is Clear:
If you want to see if bit 2 is Set:
you can use & 4 instead but its easier doing the above as you dont need to work out bit 0 is 1, bit 1 is 2, bit 2 is 4, bit 3 is 8 etc
Hope that helps?
(Variable & (1 << bit)) <> 0 // to Check if bit of variable is setCode: Select all
(Variable & (1 << bit)) = 0 // to Check if bit of variable is ClearCode: Select all
If (Variable & (1 << 2)) = 0 Code: Select all
If (Variable & (1 << 2)) <> 0 Hope that helps?
lungchard
- Flowcode v5 User
- Has thanked: 1 time
- Been thanked: 3 times
Hello Martin,
Tnx for the reply, especially on a Sunday!
Do i just enter your suggested text into the decision block or is there more to it?
Best Regards
Richard Hogan.
Best Regards
Richard Hogan.
You're welcome.
Within the decision macro, Just replace the the name with the actual variable you are interested in.
Also replace the with a number that represents the bit you are interested in.
For example if you want to test bit 4 of a variable called temp3 you either use:
or
You need to remember for 8 bits, lowest bit is 0 and highest bit is 7
If you get stuck just upload your flowchart.
Variable Also replace the
bitFor example if you want to test bit 4 of a variable called temp3 you either use:
(temp3 & (1 << 4)) <> 0Code: Select all
temp3 & 16If you get stuck just upload your flowchart.
lungchard
- Flowcode v5 User
Hello Martin,
Just the ticket!
Does what i need but rest of my code needs some minor tweeks to get the displayed temperature to show correct value when the 4 digits have values of 0001. This corresponds to a temperature of 0.0625 but LCD currently shows 0.625.
Need to figure out how to get a leading zero on this value only.
All other combinations of the bits result in a 4 digit value that displays correctly.
May have to force a 0 to the LCD if only bit 0 has a value of 1.
Same applies to bit values of 0000. This shows 0.0 on the LCD. I would prefer to see 0.0000 but that is for another day.
Many thanks again for your help.
Best Regards from Thailand,
Richard Hogan.
Just the ticket!
Richard Hogan.
