I am not able to get Ghost, on a BL0032, working on FC8 so I've reverted to FC7.3.0.7. The problem experienced here is that the Ghost feature isn't recognized, i.e. ICD and ICT icons are not active although the BL0032 is recognized as the target and it is possible to download a hex file to the PIC. I have used several different ports so as to ensure that I'm not using the ICD lines.
Is there any set up that I need to do on the BL0032 apart from selecting it as a target? The eblocks2_datasheet doesn't give much information; I can't seem to find the PIC in the schematics. I would appreciate any assistance.
Kind regards.
Leo
Ghost not active on BL0032
Re: Ghost not active on BL0032
Hi Leo,
Which version of Flowcode 8 were you using. Just tried it here and the buttons are becoming available for me with a BL0032 board connected.
For Flowcode 7 have you applied the latest fixes listed here?
viewtopic.php?f=63&t=19743
- Flowcode V4 User
- Has thanked: 41 times
- Been thanked: 9 times
Hi Ben,
Thanks for getting back to me. I'm running 8.2.2.16 on the laptop and 8.2.1.13 on this desktop.
Yes, I did a complete FC7 reinstall on the laptop last week and applied the fixes at that time, and have now applied then here too. The fault remains in that when the BL0032 is connected the ICD and ICT buttons stay inactive. FC7 doesn't see the BL0032 as a target until the Mloader folder is replaced with the one from the FC8 folder, then the hex file can be downloaded and everything runs OK. The ICD and ICT buttons remain inactive.
FC8 has a different problem in that the Ghost buttons are all active. If you Step Into the program, the Run (as expected), Step into and Step Over buttons are inactive and nothing happens until you Stop. All Ghost buttons are then active but when you try to Step Into or Run again, Ghost reports that "the chip does not contain the latest ICD build, etc". Compiling to chip starts the whole process over again.
Kind regards.
Leo
Kind regards.
Leo
