I have a problem.
PIC32mz2048efh100 with 24Mhz external clock.
200Mhz system clock
Uart3 = 9600 baut
sends with 2400 baut.
download/file.php?mode=view&id=31652
where is the mistake?
Pic32MZ2048EFH100 /200Mhz Uart's too slow
- Oit Heizung V1.fcfx
- (17.55 KiB) Downloaded 445 times
- Has thanked: 182 times
- Been thanked: 179 times
Re: Pic32MZ2048EFH100 /200Mhz Uart's too slow
Hi Speed64
You can insert a C Code with a line like this.
This C Code has to be after the init the Uart!
I did not try the 9600 baud but for the 115200 it's working nice.
U1BRG=2592; // setzt uart 1 auf 9600
U4BRG=216; // setzt uart 4 auf 115200
Hi Speed64,
before changing any register values, make sure that clock speed and configuration settings are correct.
You can do that by running a 1 second flash test.
hello medelec35
I have the test via an interrupt (clock 10ms) in the software
Interrupt call "measure"
in "Measure" count up to 50 then set A6 = 1
and count up to 100 then set A = 0 and count to 0
so on, that works ok
hello stefan.erni
it works now
is that a compiler error?
normally this works for most chips without the C code
Thanks again
hello stefan.erni
it works now
Thanks again
Hi Speed64, Hi Medelec
PIC32MX and PIC32MZ have different value for the Baudrateregister and there is a BRGH Bit to set or clear.
I don't really know that either. But the problem is just in the PIC32MZ and not in another PIC like PIC16.
Have you done a 1 second flash test to confirm your micro is running at the right speed?
https://www.flowcode.co.uk/wiki/index.ph ... ED_flasher
hello stefan.erni , medelec35 , Benj
the C code here from stefan.erni has helped. Danke
U3BRG=2592; // setzt uart 3 auf 9600 // sets Uart3 to 9600 baut
According to the data sheet, this is a divider for the UART
a bug for me
does the value have to be changed when the clock is changed?
Hi Benj
Yes of course
I tested it as described above
Thanks again
a bug for me
Hi Benj
Yes of course
Thanks again
