Need help in array calculation
Put data in array through keypad then combine it in integier variable. When i press 1234 the result is same 1234. But when i put 12 the result is 1200 insted of 12. Please help to solve this problem
- Flowcode1.fcf
- (13.5 KiB) Downloaded 216 times
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Need help in array calculation
One way is to perform the final calculation differently depending on the value of Key_COUNT.
For example, when Key_COUNT is 4 then "Result = Key_ADD[0] * 1000 + Key_ADD[1] * 100 + Key_ADD[2] * 10 + Key_ADD[3]" is correct.
But for Key_COUNT = 2, "Result = Key_ADD[0] * 10 + Key_ADD[1]".
Another way would be to keep a running total of the result as the keys are entered. Each time a new on is entered, the existing result needs to shift one decimal place and the new key result becomes the lowest digit.
Hi kg300, attached simplified flowchart might help.
The target device you are using will not have enough ram to compile either flowchart.
the * key is used to clear the result
- Flowcode1a.fcf
- (13 KiB) Downloaded 210 times
