PIC18F45Q10 ADC
dz28
Has thanked: 7 times
Been thanked: 9 times
PIC18F45Q10 ADC
Post by dz28 »
Using the PIC18F45Q10 and the ADC is not working in Hardware.
Simulation is fine inside of flowcode.
I had a similar problem with the ADC on the PIC18F25Q10 part.
Hopefully it is a similar solution.
Thanks,
Dave
Re: PIC18F45Q10 ADC
Can you be more specific?
You mean you can't select FVR?
dz28
Re: PIC18F45Q10 ADC
Post by dz28 »
I have not got to trying FVR yet but I see it in the Drop down.
I expect to need a C code block to select the FVR voltage.
For now I am just doing a simple test to check the ADC functionality.
Reference is Vdd, Pin An19
Just reading a slide pot with "GetInt" and displaying the result on a display.
FlowChart attached.
Thanks,
Dave
AD_Test.fcfx
(9.73 KiB) Downloaded 213 times
dz28
Re: PIC18F45Q10 ADC
Post by dz28 »
For a reality check I swapped out the PIC18F45Q10 with a PIC18F45K40
and the ADC works correctly including the FVR register.
The Chips are functionally similar so it looks like there is a real issue with the PIC18F45Q10 part.
Thanks,
Dave
dz28
Re: PIC18F45Q10 ADC
Post by dz28 »
Has there been any movement on this issue?
Thanks,
Dave
dz28
Re: PIC18F45Q10 ADC
Post by dz28 »
Ben,
Sorry to push ...
Do you know if this issue will be resolved soon?
Should I pick another Chip to develop with or move it to MPLab.
Thanks,
Dave
Re: PIC18F45Q10 ADC
Hi Dave,
I'll have a look into this for you today and see if I can work out what the problem is.
Re: PIC18F45Q10 ADC
I've now had a go at making a change that will hopefully allow the ADC to work on the Q10 devices.
Let me know how you get on.
dz28
Re: PIC18F45Q10 ADC
Post by dz28 »
Ben,
Sorry to report things are still not working.
Tried AN1 and AN16
Verified voltage on A/D input pins
A/D Setup
VDD
Fosc/32
40
Thanks,
Dave
dz28
Re: PIC18F45Q10 ADC
Post by dz28 »
Ben,
Any updates on this problem?
Thanks,
Dave
