Touch Pad help!
seokgi
Has thanked: 18 times
Been thanked: 16 times
Touch Pad help!
Post by seokgi »
Good morning?
I am doing a program that uses a touch switch.
But there is no reaction at all. I also reported an example, but it doesn't work. Someone please help.
MCU: PIC18F47Q10
Shoes_Case.fcfx
(25.3 KiB) Downloaded 157 times
Re: Touch Pad help!
The sim seems a bit broken for the component I'll see if I can get this fixed for you. It is working it's just the switch doesn't quite move like it should be.
In the component properties you have the values on = 100 and off = 50.
In the GetTouchPressed macro call you are using the values 100 and 200.
Try changing these to 50 and 5 and the switch should work as expected. This isn't my component and I'm not too sure what the parameters mean.
