PWM ARDUINO 2560
maxtisc
Has thanked: 2 times
Been thanked: 9 times
PWM ARDUINO 2560
Post by maxtisc »
I'm using the PWM output in the property menu I see that the maximum settable overflow period is 255, even if from datasheet the overflow period for channel 10 is 16 bit, the question is whether it was possible to set 16 bits would increase the output resolution?
thanks
(146.77 KiB) Downloaded 73 times
(115.16 KiB) Downloaded 73 times
