I'm still very new to Flowcode and I am hoping to write a project that works on a custom design. I have a board that has many MOSFET switches driven by MCP23107 IO expanders. Is there an LED or other indicator I can use to test the outputs of the IO expanders?
MCP23017 Output Test
Re: MCP23017 Output Test
Do you want to test it in simulation or on actual hardware?
You can't currently connect the sim expander pins to a LED though we have discussed making this a possibility but on actual hardware yes using a LED is a good idea to sanity check it's working ok.
- Been thanked: 1 time
