Uart!
- Has thanked: 1135 times
- Been thanked: 299 times
Uart!
Hi!
i am playing with seriel wireless TX and RX. Working ok.
In the Component Macro I can send a CHAR and receive the CHAR. And if I say ; "If receiving char, then do something. Working."
I see it is possible to send a number, but how do I receive it, please?
Br Jorgen
Br Jorgen
mnf
- Has thanked: 70 times
- Been thanked: 440 times
Re: Uart!
Hi Jorgen,
Send number converts the number to an ASCII string and sends that - you could receive that and convert back. Alternatively spilt into bytes and send and recombine..
I can do a simple example if it would help..
Re: Uart!
Hi Martin!
Oh yes, I will be gatefull if you will create a small program for this. Tx and rx. At the moment I use Arduino Nano.
I can att. my programs if it do a difference (tomorrow).
Thank´in advance.
Jorgen
Thank´in advance.
Jorgen
mnf
Re: Uart!
Okay - a small program. This watches UART2 (here a software channel - receive on D2, Tx on D3) - looking for numbers sent as a string (using SendNumber - or in my case putty and a FTDI converter...)
A number of up to 10 digits is converted to a 32 bit unsigned int (so max is 2^32-1) and the string and number 'displayed' by sending to UART1 (another putty terminal on PC)
So '0003' = 3 '1234' = 1234 etc. End of number is any non-numeric character.
Re: Uart!
Hi Martin!
Thank you very much for your effort, but honest I don´t understand the program. I am not so hardcore
What I trying to make is a wireless remote control. I will send a number, then the receiver reconise this number and activate an output.
It working but I want, as long time I send the number the output is activated on the receiver, and emidiately I stop transmit the output goes low on receiver, (My problem). On this way I can make multible on off output by using the Uart. Hope it make sense and you understand what I mean?
I am not home at the moment, but when I come home (tomorow have the program on another PC) I will att. the program for the transmitter and reveiver I have created.
Thank´s in advance
Jorgen
Thank´s in advance
Jorgen
mnf
Re: Uart!
Hi Jorgen,
Not quite sure I follow what you want - I think it is:
1) Receive a number (say 1)
2) Turn on an output (port 1 in this case)
3) When number finishes port goes off ? or
3) Wait for another command to turn port off?
The above example - the main loop just waits for a string of characters (any of '0'..'9') to have been received (signalled by got_number being set to true by the interrupt) - most of it is concerned with converting this to an integer and displaying the data to the user..
The interrupt routine does most of the work - watches the UART port for data - if it's a number (0..9) it adds it to a 'string' - if it's not a number - then it signals the main program that a number has been received (if the string contains any characters...) by setting got_number to true.
- Has thanked: 182 times
- Been thanked: 179 times
Re: Uart!
Hi Martin, Hi Jorgen
For some command for the uart I add this "\r\n" on the end.
So the terminalprogram shows a new line for each command. And the most terminalprogram add it automatic.
In the receiving part of my FC progamm I used it for a control.
To use the interrupt I choose the pin from the PIC with uart receive.
It's working to send a command from the terminalprogram like stepa50 (\r\n)
I use this few c command:
You can have a look to the macro Int_uart5 in the program
ser_str_command = Left$ (ser_ret_str_bt,5) // get the command without /r/n
ser_str_parameter = Mid$ (ser_ret_str_bt,5,ser_ret_length - 7) // get the parameter
ser_str_parameter_int = StringToInt$ (ser_str_parameter) // convert to integer-
Re: Uart!
Thank's Martin and Stefan
In my testprogram TX send Char 44. In RX I receive the char 44 then CH1 is going on.
But I want CH1 go low again emidiately when I stop transmit.
Is it possible. I would like to add multible channel, to maually be able to control my lawnmover
Thank´s in advance
Jorgen.
Thank´s in advance
Jorgen.
mnf
Re: Uart!
Hi Jorgen,
Okay I see what you want to achieve...
Should be fairly straightforward to 'watch' for input (44) and if nothing has been received for a set time then turn off output.
Then if a byte is received - turn on again.
Maybe a 'watchdog' if transmitter goes out of range?
mnf
Re: Uart!
So - a simple version.
Here an interrupt on UART Rx watches for character 44. If it is found it turns on the 'output' (here the inbuild LED) - and resets a timer.
The second interrupt (a timer) - increments the time, and if > DELAY (a constant) turns off the LED. Note that the timer runs at ~0.9Hz (I call it bogosecs - so delay of 5 gives (~6) edit - no 5 * .9 = ~4.5 secs output if no further signal received) You could tweak the timer interrupt to run much faster if needed to stop the output very quickly. Edit - my maths is all to pot - 0.9Hz is a cycle of ~1.1seconds.. In my defence - it was a very busy day...
The main loop here just outputs LED OFF or ON (and time on) and isn't really involved at all - apart from a bit of setup.
Re: Uart!
Hi Martin!
Working perfect
Thank you very much.Now I will try to increace channels output. But Martin what does \r\n mean, has it something to do " go to new line" if writing in display?
Thank´s
Br. Jorgen
Working perfect
Thank´s
Br. Jorgen
mnf
Re: Uart!
Glad to hear working okay.
Yes, \r\n is Return Newline - really goes back to the age of teletype. Return moves back to the start of the line and newline advances to the next line. There are several of these 'escape' characters (for example Bell - which should make a sound (originally a bell as on a typewriter))
Re: Uart!
Hi Jorgen, Hi Martin
This "\r\n" is practicel to send to a terminalprogram. It makes you a new line. Most terminalprogram can also make a log file. So you will have there a new line too. With a little more character you can easy log an .CSV file. (a simple excelfile)
There is an another way to send this two ascii code :
Re: Uart!
Hi Stefan!
Thank you very much for the tips.
At the moment I working on a wireless remote control. Later I will definitely play with wireless send string to a display, then I can use your tip.
Br Jorgen
Br Jorgen
