Flowcode6
buvaylov
Flowcode6
Post by buvaylov »
Hello! Please help with an example of entering a value (for example 1155, 8888... 4125) from the keyboard into a variable integer type
Re: Flowcode6
To do something like this you would have a routine like this. Written in pseudocode.
done = 0
var = 0
while (done != 1)
  key = ReadKeypad()
  if (key < 255)
    if (key > 9) then done = 1
    if (key <= 9) then var = (var * 10) + key
  while (key < 255)
    key = ReadKeypad()
Hope this helps.
buvaylov
Re: Flowcode6
Post by buvaylov »
Hello! Thanks for the example. Please indicate an error in the attached file. It is necessary to reflect the value of the variable(var) on the indicator. Thanks in advance
1. Keypad.fcfx
(6.74 KiB) Downloaded 169 times
Re: Flowcode6
Hi buvaylov,
Does this work better for you?
1. Keypad.fcfx
(7.2 KiB) Downloaded 171 times
buvaylov
Re: Flowcode6
Post by buvaylov »
Hello Martin! Thank you for your help. I am making a winding machine and want to know if I can contact you for project advice in the future. Regards, Alexandr
Re: Flowcode6
Hi Alexandr,
Your welcome.
If you get stuck, then I will help you if I can.
Re: Flowcode6
Hi Alexandr,
Can you ask for help via main forums please and not via PM as its against forum rules.
Issues with your flowchart is you need to add a LCD start component before the main loop:
Within configuration settings, you will need to change RC to XT as RC is only If you have an external resistor and capacitor connected and not a crystal or resonator.
