I would like to integrate C and assembler into flowcode.
Because the editor in flowcode is not the greatest, I want to use MPLabx as the editor.
I find I can include a c file at the beginning of the main flowcode program and this gets compiled into the code.
#include "ThyExternal.h"
in the supplementary defines and this works ok.
What I can't do is call a c routine from an interrupt routine. They have the wrong scope. I also can't place my own interrupt routine.
I also want to include an assembler file into the project. I can't get this right without using
asm (" mov W0, TBLPAG ") ; Which is very painful.
I also have a licensed copy of XC16. But if I point to that in your batch file the linker commands are all messed. It would be nice to get the latest compiler with optimisations working in flowcode.
And finally, I would like to incorporate flowcode into an MPLAB project and compile from there. Then I could debug properly. I think this relates to the above problem so if I get the correct linker then the whole project should compile in mplab. This would solve everything as I could then use assembler with no problem.
Thanks in anticipation.
C Programming Microchip
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: C Programming Microchip
Thanks for the feedback. Here are some suggestions:
In the interrupt icon properties, you can select "custom" in the "interrupt on" drop-down and then select "properties..." which will allow you to customise your enable/disable and handler code.gianV wrote: What I can't do is call a c routine from an interrupt routine. They have the wrong scope. I also can't place my own interrupt routine.
You might be able to add specific assembly files onto the command line for compilation and/or linking. Do this by either editing the batch file or creating a new entry in the compiler options screen.gianV wrote: I also want to include an assembler file into the project. I can't get this right without using
Again, you should be able to create a new entry in the compiler options screen. This screen is not the most intuitive to use, though.gianV wrote: I also have a licensed copy of XC16. But if I point to that in your batch file the linker commands are all messed. It would be nice to get the latest compiler with optimisations working in flowcode.
We looked into this a long time ago and it did not seem easy to do. Perhaps it is easier now in MPLABX? We are very busy right now with a new version of Flowcode so I can't look right now, but I will try to find the time in a few months.gianV wrote: And finally, I would like to incorporate flowcode into an MPLAB project and compile from there. Then I could debug properly. I think this relates to the above problem so if I get the correct linker then the whole project should compile in mplab. This would solve everything as I could then use assembler with no problem.
