Is it possible for an analog multiplexer to convert a biopolar signal to a unipolar signal? I'd like to use a homemade oscilloscope to measure positive and negative voltage.
Thanks!
Analog Multiplexer for ADC Stm32f103c8t6
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Analog Multiplexer for ADC Stm32f103c8t6
As you probably realise, the ADC will only be capable of accepting input voltages between its power rails.
So you would need to buffer the signal with an Op Amp so as to provide a gain or signal reduction
as well as an offset such that 0v at the test point gives mid-rail at the ADC input.
Google some Op Amp circuits
- Has thanked: 187 times
- Been thanked: 205 times
Following on from Leigh, this gives some examples of what you are trying to achieve.
https://ocw.mit.edu/courses/media-arts- ... 2_bias.pdf
