Hi. Recently, flowcode has started showing a "google tag manager script error" every time flowcode starts. This happens on both computers. If I click ignore, it carries on and seems to work. Is there anything I need to do to make this go away.
I have searched google for the problem, but ended up more confused than ever when it started mentioning registry hacks.
Any help, or advice would be very much appreciated.
Regards John
Script error on starting flowcode
- Been thanked: 3 times
- Has thanked: 187 times
- Been thanked: 205 times
Re: Script error on starting flowcode
This link may be helpful
https://developers.google.com/tag-platform/gtagjs
It explains the use / benefit of using google tags if you are a web developer / owner. I get the same issue if I open v7 and I'm guessing the issue is that the tag it refers to is deprecated or such like. It won't affect Flowcode itself, so it is safe to just close the window.
As v7 is rather old now I'm not sure if the tag will be fixed or not.
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
This error is probably caused by old tags in the Welcome Page, which is generated by our website. I will look into this next week as it should be an easy fix.
Until then, please ignore this error.
