3.5inch Arduino Display ILI9486
dds.m.blal
Post by dds.m.blal »
I bought a "3.5 inch Arduino display ILI9486" ,This is the product website http://www.lcdwiki.com/3.5inch_Arduino_Display-UNO
But I did not find the model of this screen on flowcode 8
Can it be turned on somehow?
Has thanked: 187 times
Been thanked: 205 times
Re: 3.5inch Arduino Display ILI9486
As v10 doesn't feature a ILI9486 display I doubt v8 would either. However from a quick search it seems the ST7796 driver is very similar so you may be able to use a component based on that instead.
dds.m.blal
it have 8pins as data and 5pins
Again a quick search suggests that the following drivers are compatible, differences being screen size or bus:-
HX8369 / ILI9488 / ILI9806 / ILI9327
The ILI9488 component is available for 8 / 16 pin parallel so perhaps try that? You will need to experiment regarding max screen size etc.
