In your example program on rs232 what do the following refer to
also i see this cropping up in programs "==" what does this do.
cheers guys
Ian
RS232 help
- goldwingers
- Been thanked: 1 time
Hello Ian
These commands are all comparisons.
> means greater then.
5 > 3 would return true (1)
3 > 5 would return false (0)
3 > 3 would return false (0)
< means less then.
5 < 3 would return false (0)
3 < 5 would return true (1)
3 < 3 would return false (0)
== means logically equal.
3 == 5 would return false (0)
3 == 3 would return true (1)
> means greater then.
< means less then.
- goldwingers
reply...
Hi Beng
I get that but in your RS232 sample flowcode you ask if the input is anything other than 255 this is then followed by another decision box with the following
What are these char's im supposing they are < & > but what does it do?. the return char's as in the program.....(CHR<>60) AND (CHR<>62)
Cheers Ian
Cheers Ian
RS232 Question
Hi Guys,
Another RS232 Question. I know from previous threads that the RS232 component assumes a Xtal speed of 19.96MHz and that to adapt this to other Xtals you need to edit the C code.
Could you please elaborate on this a little. Specifically what (register?) do you edit and how do you derive what the new value should be for the new Xtal.
MW
MW
Hello Ian
In the example CHR <> 60 means not equal to 60.
eg
if CHR = 59 then CHR <> 60 returns true (1)
if CHR = 60 then CHR <> 60 returns false (0)
You can also use the following instead to do the same function
CHR != 60
eg
CHR != 60
Hello MW
The clock speed in Flowcode is set via the Chip -> Clock Speed menu.
Once this setting has been set correctly you can go into the properties for the RS232 component and adjust the baud rate accordingly.
No edits to the C code are required.
- goldwingers
