How do i send data as a string to the com port. The string would be something like "1,0,1,13,10" equating to
sw1 =1
sw2 = 0
sw3 = 1
cr
lf
I need to send the string as seen (including the inverted commas). The program I am using needs to take this as a string and it is then decoded
Sending strings
- goldwingers
- Been thanked: 1 time
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Here's one way...
//decision
if (sw1 = 1)
//Component Macro
SendRS232Char("1")
//else
//Component Macro
SendRS232Char("0")
//end if
//Component Macro
SendRS232Char(",")
...etc...
- goldwingers
- goldwingers
Errrr
Hi Steve
I have tried to insert "SendRS232Char("1") " into a send box but it does not accept ("1") or do i need to type in char("1")?
cheers
Ian
cheers
Ian
Hello Ian
Try using '1' instead of "1"
- goldwingers
Hi Beng,
The program for my Gui needs the data to be in inverted commas ie
data sent = "1" This is a down fall of the gui program not flowcode.
I have assumed that char (20) is the number for the " so I have tried sending as follows
send rs232 - char20
send rs232 = 43
send rs232 - char20
send rs232 - char 13
send rs232 - char 10
this should give me a string of "43,13,10" but the program im using dont see the inv commas
send rs232 - char20
send rs232 = 43
send rs232 - char20
