Float point help!
Teo
Float point help!
Post by Teo »
Hi, I'm registrate user, please post example with convert 0-1023 to 0.00-100.00(2 decimals) use the thermometer and lcd components.Please post the real help for float point instructions and moore examples.Sory for my language.Thanks!!!!
Hello Teo
Everything you need to get started with floating point is available from here.
http://www.matrixmultimedia.com/support ... .php?t=505
Try doing a little bit at a time rather then taking on the entire task all at once.
Let me know if you get stuck.
Teo
Post by Teo »
Hi,thanks for answer . How change the value of radius with value from ADC or thermometer component in float32 example? Thanks!!!!
Firstly you need to read in the ADC value into an Int variable.
Then you will need to use C code to convert this Int into a float variable.
Then you will have to create a second float variable and assign the value of 10.23.
The you can devide the ADC result variable with the constant variable to get your range of 0 - 100.
You can then multiply the result by 10 to get a range of 0 - 10000. Then convert this variable back into an Int and you can then use flowcode to print out the number.
The 10000 wil represent 100.00
Teo
Post by Teo »
Thank you very much! I declare 'a' int variable and radius = float32_from_int32( a );
and dont work :oops:
C:\Documents and Settings\dumitru.teodor\Desktop\FLOWCODE\float32\float32.c(564:31): error: unknown identifier 'a'
C:\Documents and Settings\dumitru.teodor\Desktop\FLOWCODE\float32\float32.c(564:29): error: arguments of 'float32_from_int32' don't match the parameters of call
C:\Documents and Settings\dumitru.teodor\Desktop\FLOWCODE\float32\float32.c(564:11): error: failed to generate expression
C:\Documents and Settings\dumitru.teodor\Desktop\FLOWCODE\float32\float32.c(564:11): error: invalid operand 'float32_from_int32( a )'
C:\Documents and Settings\dumitru.teodor\Desktop\FLOWCODE\float32\float32.c(564:9): error: failed to generate expression
float32.c success
please help!
Ok I can see where your going wrong.
If you create a variable in flowcode eg "a" then the C equivalent of that variable is "FCV_A".
so to clarify
Flowcode variable a becomes C code variable FCV_A
Flowcode variable var1 becomes C code variable FCV_VAR1
etc.
Hope this helps.
Teo
Post by Teo »
Thank you very much! Now is OK!!!! :D
