Problems with LCD
Jan Middel
Problems with LCD
Post by Jan Middel »
I have problems with mij LCD routines
When i make a digital clock it works wen im simulate it on my Pc
When i putt it in my pic 16f88 then i get this error :
Warning unreferenced functions removed:
FCD_LCDDisplay0_Start in: D:\Jan_Elektronica\flowchart_routines\Tuinverlichting_versie3_flowcode_oude_versie.c
FCD_LCDDisplay0_PrintString in: D:\Jan_Elektronica\flowchart_routines\Tuinverlichting_versie3_flowcode_oude_versie.c
Warning: function never returns: 'FCM_Hoofdlus'
Building CASM file
Memory Usage Report
RAM available:368 bytes, used:25 bytes (6.8%), free:343 bytes (93.2%),
Heap size:343 bytes, Heap max single alloc:110 bytes
ROM available:4096 words, used:543 words (13.3%), free:3553 words (86.7%)
Successful
Return code = 0
Launching the programmer...
Sending program...
Erasing the PICmicro
Writing program memory
Writing configuration memory
Writing id-locations
Reading program memory
Reading configuration memory
Finished reading PICmicro contents
Program sent and verified OK
543 out of 4096 program words used
0 out of 256 data bytes used
That took 1,36 seconds
Return code = 0
FINISHED
Can anybady tell my woth the problem is
If reinstald de sofware but it works not.
Groeten Jan Middel
The messages say that compilation was successful.
However, it looks like you have not initialised the LCD using the "Start" macro. You need to do this before using any of the other LCD functions.
Note that when simulating, you do not need to call this "Start" macro. But you must use it when running on the microcontroller itself.
