I receive this error while compiling.
any idea`s ?
thanx
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "TEST.c"
BoostC Optimizing C Compiler Version 6.70 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2007 Pavel Baranov
Copyright(C) 2004-2007 David Hobday
Compiler can not be started without a host program (code 120)
Return code = 120
Flowcode kan de C-code niet vertalen vanwege de volgende fout:
Als de flowchart C-code bevat, controleer die dan zorgvuldig. Als de flowchart geen C-code bevat of als die gegarandeerd vrij is van fouten, neem dan contact op met de technische ondersteuning.
FINISHED
It sounds like your BoostC compiler is not recognising that it is being called via Flowcode.
Has Flowcode ever worked correctly on that particular machine?
Have you tried uninstalling and reinstalling Flowcode?
Do you have Admin privaliges?
One fix may be to go into Chip -> Compiler options and restoring the defaults.
If this does not work then here is a registry fix that may solve your problem.
http://matrixmultimedia.com/support/fil ... ce_fix.zip
Let me know how you get on.
