8-bit calculator project, tips needed!
Thirtyfour
Post by Thirtyfour »
I'm a new user in flowcode, and i'm in need of some tips to make a eight-bit calculator, which lights the leds in order of 0=>255. The problem is that i don't get how this program works.
I know that i can make it with 255 outputs, but what'a heck :P...
I also know how to make this project with C++, but the flowcode is quite different than writing a clean code.
So what is the best and easiest way to make this project? The PIC that i use is 16F84.
Are the LEDs connected to a single 8 bit port.
If so then in Flowcode simply create a byte variable called count.
Then create a while loop and in the propertys input add
count < 255
Then inside the loop create a output icon that outputs the variable count to PortB then create a calculation icon with count = count + 1
You may also need a small delay inside the loop so that you can see the LEDs counting from 0 to 255.
