Programming in C
For Formula Flowcode Micromouse users to discuss projects, flowcharts, and any other issues related to the Formula Flowcode Micromouse.
tekruma
Programming in C
Post by tekruma »
It's fun and easy to program the Formuala with help of Flowcode. But is it possible to program the Formula with a standard C compiler?
Rolf
Yes - it is possible. But make sure the code for your program is relocated to 0x800 because there is a bootloader in 0x000 to 0x7FF.
tekruma
Programming in C
Post by tekruma »
Intersting but how is that done?
I suppose the C compiler must know something about Formuala and how do I transfer the C code to Formula?
Rolf
For the BoostC compiler, you must use the following linker parameter to relocate the code:
-rb 0x800
I do not know about other compilers.
The "BuggyProg.exe" program that is installed with Flowcode can be used to send programs to the buggy. This is in the same folder as the Flowcode exe.
tekruma
Programming in C
Post by tekruma »
I have got the BoostC compiler but where do I insert the code -rb 0x800 ?
Rolf
You will need to add this to the "extra linker options" entry within the SourceBoost IDE.
Sofie
Re: Programming in C
Post by Sofie »
I tried to do everything you said:
linkeroption in Sourceboost : -rb 0x800 and compile and link
When i send this to the pic using buggyprog, i always get the error: send Failed...
Can you help me
(excuse me for my english)
This FAQ topic adopted for the formula flowcode should help to get you up and running.
http://www.matrixmultimedia.com/support ... f=20&t=537
