Hi there,
I want to use the 18F2480 with flowcode. The code run's in simulation.
When compiling and uploading, no errors appear.
However, the 18F2480 doesn't run.
It must be one of the settings I think.
However, when I change one of the settings, and try uploading it again, a message apears that the 18F2480 can't be erased.
Does anybody have any suggestions on this? Please let me know.
Is there some kind of list with best settings for flowcode with several different kind of PIC microcontrollers?
PIC 18F2480 with Flowcode
- Flowcode v5 User
- Been thanked: 3 times
Hello Steve,
I'm using the E-blocks Multiprogrammer with LCD on port B, some inputs on port A and C, outputs on port C. It is a standard counting system.
The 18F2480 is programmed without errors, but the program doesn't start in the hardware. Also a simple testroutine like writing text on the LCD doesn't run. There always seem to appear a problem with the multiprogrammer because of some settings.
Programmed for the second time, the PIC is not erased and a message appears. I have to erase the PIC in another programmer with MPASM.
After that I can program without errors again, but it still doesn't run.
Greetings, Rinie
Flowcode V7 user
Flowcode V7 user
