Some math(s) expressions are calulated incorrectly
This is an error within simulation only. The error does not occur with programs running in the microcontroller.
The order of precedence of mathematical expressions within calculation, decision and loop icons is not totally correct when simulating a program. The precedence of *, / and MOD is higher than + and -, but + and - share the same precedence as other operators such as "<" and "&&".
This is not correct: "+" and "-" should be of a higher precedence.
To work around this problem, make sure you use parentheses (brackets) to make the calculation's meaning explicit.
