Custom_Code.c coding help:Perl script
Forum for problems or queries regarding other Flowcode Components. Eg LEDs, Switches, LCD, Gfx LCD etc
nils
Post by nils »
I alread posted my script in the Component vote thread, but am not quite sure if every one has seen it, or I may be the only one who forgets to set the code right or makes typing errors. ;-)
Anyway, I coded a script, that sets inside the Custom_Code.c file the corresponding MacroReturns, MacroNames and so on, so that YOU do not need to care about them while implementing new functions to the file. I sometimes was tired of editing these descriptions when I tried to implement different things and finally wrote a Perl script that now does the job for me, so I can concentrate on ONLY writing the C code and nothing else, an easy "perl set_code.pl" on the command line does the job and you're done with it.
well, it may not be for everyone, but it helps me from now on in new projects so that I don't have to care about how many functions I am writing and so on. now it is coding -> perl script -> flowcode implementation -> done! and no more fiddling with spelling errors.
for setting things up, there is a short description at the beginning of the script.
cheers and have fun,
Nils
PS: you get a free Perl version for windows @ activestate.com
PPS: if you find bugs or have ideas what to implement next, write it down in this thread and I try to figure it out.
PPPS: I WILL POST NEW VERSIONS EVERY ONCE IN A WHILE, SO LOOK FOR THE LATEST ONE IN THIS THREAD AS I WILL NOT UPDATE THE DOWNLOAD LINKS
set_code.pl.zip
(3.68 KiB) Downloaded 960 times
Custom_Code.c help needed? -> http://tinyurl.com/2y2mzq
Flowchart high quality vector graphic output =>>http://tinyurl.com/6sx2sx
Re: Custom_Code.c coding help:Perl script
Hello Nils
I had thought of creating a Perl or PHP script to do this but never managed to get around to it.
Thanks for your input. I hope you will be happy in the knowledge that your code will aid us to creating new components. :mrgreen:
If I find bugs, incompatibilities or problems with the code then I will let you know here.
Thanks again.
nils
Post by nils »
I thought you would ;-)
it is not completely bug proven, but it works for me. unfortunately it does not contain compatibility to your style of coding i.e.
void something()
    some code;
    more code;
in contrast to mine that is
void something(){
    some code;
    more code;
but maybe you have the excellent solution and can contribute on the script :P
nils
Post by nils »
dupe, double post ;)
nils
Post by nils »
so if anyone is interested in what my script is doing (in a brief explanation + flowchart), I wrote up a little LaTeX document to introduce my script and the "Macro" definitions I am altering/generating with it.
hope it helps people that were a bit helpless like me seeing the Custom_Code.c file for the first time :shock:
cheers,
nils
Custom_Code.pdf
(116.46 KiB) Downloaded 1050 times
Hello Nils
Just had a look through your PDF. It's fantastic, thanks for all the work you have put into this. I have yet to verify the script itself but the next coding that I do I will try it out.
Thanks again.
Ben
nils
Post by nils »
version 1.1b_2
hi there
this evening I tweaked a bit the code for supporting different styles of braces, as I know that you folks of MM do it another way as I do, and maybe others out there too. now following things are possible:
void something1(){
    some code;
    more code;
void something2()
    some code;
    more code;
void something3()
{   some code;
    more code;
void something4()
{   some code;
    more code;}
there are a few things missing, but I hope you like it anyway.
I used it a few times this week while adding/deleting functions and it worked like a charm :mrgreen:
edit: added support for closing curly braces, wherever they may be. only thing with braces not working is some weird stuff like the following code, but this is REALLY ugly IMO:
void Test(short Foo){int Bar;
    more code;
PS: comments and bug reports are always welcome.
set_code.pl_1.1b_2.zip
(4.29 KiB) Downloaded 777 times
nils
Post by nils »
version 1.2
changed recognition of functions, so that ugly things like this one
void Test(char Foo, short Bar){ugly code; do not try to do so;}
will result in
/*Macro_Test_Start*/
/*Macro_Test_End*/
and now time stamps of the backups are a bit nicer than before e.g. Custom_Code.c.Sat_Feb_23_13-43-23_2008.
regards,
nils
set_code.pl_1.2.zip
(4.32 KiB) Downloaded 774 times
nils
Post by nils »
Hi there
new updated version of the documentation:
- changed flowchart
- added a short description how to invoke the script in Win/Lin/Uni/Mac environments
have fun with it
nils
Custom_Code.pdf
(150.38 KiB) Downloaded 1007 times
