I was reading through some I2C posts and found a reply by Ben. In it Ben states that the I2C lines need to be pulled up. Is this a requirement for all I2C programming (even if it is not done via I2C macros)?
I was about to order some PCBs that I designed and am using the I2C lines to talk to dedicated PCBs that I am going to use for servo and LED control.
Should I use 10K resistors to pull up the I2C lines?
Ron
I2C Hardwire
Re: I2C Hardwire
Hello Ron
Yes your I2C lines SDA and SCL should both have pull up resistors of approx 4.7 - 10K to 5V.
Re: I2C Hardwire
Hello!
For faster Speed the Pull-Ups must have 1,8k!
I use 2,2k for 400kb Speed and it works fine.
Xsusakamei
Xsusakamei
Greetings
J. Schol
J. Schol
