I2C Hardwire
Posted: Sat Mar 29, 2008 2:48 pm
I was reading through some I2C posts and found a reply by Ben. In it Ben states that the I2C lines need to be pulled up. Is this a requirement for all I2C programming (even if it is not done via I2C macros)?
I was about to order some PCBs that I designed and am using the I2C lines to talk to dedicated PCBs that I am going to use for servo and LED control.
Should I use 10K resistors to pull up the I2C lines?
Ron
Ron
