Return code 120
Forum for problems or queries regarding the Flowcode application and compiler usage.
jimhumphries
Return code 120
Post by jimhumphries »
Steve/Ben:
Can you illuminate?
File name: C:\Documents and Settings\All Users\Desktop\pump current build\Pump Software\2008 files\16F4MHz files\V3pumpt40z4M.c
Generated by: Flowcode v3.2.2.40
Date: Friday, May 30, 2008 11:33:08
Licence: Professional
Registered to: Jim Humphries
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V3\boostc\boostc.pic16.flowcode.exe -v -t PIC16F876 "V3pumpt40z4M.c"
BoostC Optimizing C Compiler Version 6.70 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2007 Pavel Baranov
Copyright(C) 2004-2007 David Hobday
Compiler can not be started without a host program (code 120)
Return code = 120
FINISHED
The only C code is the short block defining some custom LCD characters and this code has compiled fine in previous files.
Jim
A footnote: Powering down the PC and then re-launching Flowcode seems to have cleared this up. Any ideas as to why it happened?
