Mixed switches
Forum for suggestions regarding the next update / release of Flowcode
jadiflow
Flowcode v5 User
Has thanked: 19 times
Been thanked: 16 times
Mixed switches
Post by jadiflow »
Currently, when you attach a switch component, all switches are either momentary or toggle. If you have one or a few of each you need to attach multiple switch components to different ports.
My suggestion is to modify the switch component so that individual switches can be specified as momentary or toggle, so you can mix 'n match at a single port.
Jan Didden
Re: Mixed switches
Hello Jan
Good Suggestion.
You can get semi-acheive this functionality by creating multiple switch components and reducing the number of switches in the properties to get the desired switches.
