Integrating flowcode boostC to MPLAB IDE
Kumaran
Post by Kumaran »
Dear Sir,
Is it possible to integrate flowcode.boostC to MPLABIDE? So that I can debug real hardware.
Thanks for your support
Kumaran
Kumaran
Re: Integrating flowcode boostC to MPLAB IDE
Post by Kumaran »
http://www.eggntomatto.com/techforum/vi ... 4&p=55#p55
abive link. I got an information about integration. Now I have integrated BoostC (trial downloded from source boost) in to MPLAB. Now I am able to debug the hardware with flow code generated C Program. However features are limited in the trial version of source boost. Is their any way to integrate Flow code boostC of my pro version. So that their wont be any code limit in compilation.
Sorry you cannot directly use the BoostC compiler with MPLAB as it was specifically designed for use with Flowcode. However you should be able to use the Assembler code generated by the Flowcode BoostC compiler inside MPLAB.
