Bit Manipulation
Kumaran
Bit Manipulation
Post by Kumaran »
I want to extract single bit data from the two bit data. How to do that? I have written a following code which is assigning two bit data to the varibles Left & Right. But I wanted it to be single bit data. only then my rest of the code will work as I wanted.
Left = New AND 0x0A ( New is two bit variable from that I want to extract the left bit and assign to the Varaible Left)
Right = Old AND 0x01 ( Old is two bit variable from that I want to extract the right bit and assign to the Varaible Right)
Direction.Return = Left XOR Right
Could you please suggest me how to do that?
Kumaran
Re: Bit Manipulation
Ok to start the microcontrollers use 8 bit variables as a minimum,
So lets say you have 2 variables
IN - contains the following bits Xxxxxxxx - We are interested in the large X bit
OUT = IN & 0x80 - Masks IN to provide OUT with the value X0000000
If we want to shift this single bit to the least significant place then we would do this
OUT = OUT >> 7
OUT then equals 0000000X
Ok so another example.
IN - contains the following bits xxxXXXxx - We are interested in the large X bit
OUT = IN & 0x1C - Masks IN to provide OUT with the value 000XXX00
If we want to shift these 3-bits to the least significant place then we would do this
OUT = OUT >> 2
OUT then equals 00000XXX
Hope this helps.
