I need help installing Flowcode 3 on my Vista 32 FUJITSU workstation. I have installed VB Runtime as per a previous post but cant get program to install . I get a fatal error message
which says " installation ended prematurely because of an error. Incidentally it installs ok on my Vista 32 laptop.
VISTA ISSUE
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: VISTA ISSUE
What is the exact error message (there should be an error number, which will help us track down the problem). Also, you could try logging the installation.
To log the installation, create a shortcut to the installation exe. Right-click this shortcut and select "properties". In the "target" box, type the following right at the end of the text that is already there (outside of the closing quote, if there is one):(note that there is a space before the "/log").
Then when you run the installation, it will produce a text file (C:\fc_log.txt) which will help debug the problem. Post this file here and I'll have a look to see what is wrong.
/log c:\fc_log.txt
Re: VISTA ISSUE
There was no error number given
The installation log is as follows
=== Logging started: 30/09/2008 10:53:59 ===
Action 10:53:59: INSTALL.
Action start 10:53:59: INSTALL.
Action 10:53:59: WiseStartup.
Action start 10:53:59: WiseStartup.
Action 10:53:59: Startup. Extracting temporary binaries...
Startup: Icon
Startup: WiseDlgSequence
Startup: Complete
Startup: Custom
Startup: New
Startup: Up
Startup: side16
Startup: top16
Startup: trash1
Startup: Music
Startup: Typical
Startup: WiseCustomCalla1
Startup: CD
Startup: Info
Startup: WiseCustomCalla2
Startup: Callwisepatch
Startup: Callpppv3
Startup: Callwiseapi
Action ended 10:53:59: WiseStartup. Return value 1.
Action 10:53:59: WiseUpgradeCheck.
Action start 10:53:59: WiseUpgradeCheck.
Action ended 10:53:59: WiseUpgradeCheck. Return value 1.
Action 10:53:59: LaunchConditions. Evaluating launch conditions...
Action start 10:53:59: LaunchConditions.
Action ended 10:53:59: LaunchConditions. Return value 1.
Action 10:53:59: WiseSetProfilesFolder.
Action start 10:53:59: WiseSetProfilesFolder.
Action ended 10:53:59: WiseSetProfilesFolder. Return value 1.
Action 10:53:59: Setup_Dialog.
Action start 10:53:59: Setup_Dialog.
Info 2898. For MSSansSerif8 textstyle, the system created a 'MS Sans Serif' font, in 1 character set, of 13 pixels height.
Info 2898. For Arial10 textstyle, the system created a 'Arial' font, in 1 character set, of 16 pixels height.
Info 2898. For Arial14 textstyle, the system created a 'Arial' font, in 1 character set, of 22 pixels height.
Action 10:53:59: Setup_Dialog. Dialog created
Action ended 10:53:59: Setup_Dialog. Return value 1.
Action 10:53:59: FindRelatedProducts. Searching for related applications
Action start 10:53:59: FindRelatedProducts.
Action ended 10:53:59: FindRelatedProducts. Return value 1.
Action 10:53:59: WiseUpgradeCheckEx.
Action start 10:53:59: WiseUpgradeCheckEx.
Action ended 10:53:59: WiseUpgradeCheckEx. Return value 1.
Action 10:53:59: AppSearch. Searching for installed applications...
Action start 10:53:59: AppSearch.
AppSearch: Property: INSTALLDIR
Signature: AppReg3
AppSearch: Property: PPPMAJOR
Signature: AppReg1
AppSearch: Property: PPPMINOR
Signature: AppReg2
AppSearch: Property: PPP_CUR_VER
Signature: AppReg
Action ended 10:53:59: AppSearch. Return value 1.
Action 10:53:59: ValidateProductID.
Action start 10:53:59: ValidateProductID.
Action ended 10:53:59: ValidateProductID. Return value 1.
Action 10:53:59: SETLICENCE.
Action start 10:53:59: SETLICENCE.
Action ended 10:53:59: SETLICENCE. Return value 1.
Action 10:53:59: CostInitialize. Computing space requirements...
Action start 10:53:59: CostInitialize.
Action ended 10:53:59: CostInitialize. Return value 1.
Action 10:53:59: FileCost. Computing space requirements...
Action start 10:53:59: FileCost.
Action ended 10:53:59: FileCost. Return value 1.
Action 10:53:59: IsolateComponents.
Action start 10:53:59: IsolateComponents.
Action ended 10:53:59: IsolateComponents. Return value 1.
Action 10:53:59: CostFinalize. Computing space requirements...
Action start 10:53:59: CostFinalize.
Action ended 10:53:59: CostFinalize. Return value 1.
Action 10:54:00: MigrateFeatureStates. Migrating feature states from related applications
Action start 10:54:00: MigrateFeatureStates.
Action ended 10:54:00: MigrateFeatureStates. Return value 0.
Action 10:54:00: SetWizardProperty1.
Action start 10:54:00: SetWizardProperty1.
Action ended 10:54:00: SetWizardProperty1. Return value 1.
Action 10:54:00: Welcome_Dialog.
Action start 10:54:00: Welcome_Dialog.
Action 10:54:00: Welcome_Dialog. Dialog created
Action 10:54:05: PPPvers.
Action start 10:54:05: PPPvers.
Action ended 10:54:06: PPPvers. Return value 1.
Action 10:54:06: WiseNextDlg.
Action start 10:54:06: WiseNextDlg.
Action ended 10:54:06: WiseNextDlg. Return value 3.
DEBUG: Error 2896: Executing action WiseNextDlg failed.
Internal Error 2896. WiseNextDlg
Action ended 10:54:06: Welcome_Dialog. Return value 3.
Action 10:54:06: Fatal_Error.
Action start 10:54:06: Fatal_Error.
Action 10:54:06: Fatal_Error. Dialog created
Action 10:54:13: WiseCleanup.
Action start 10:54:13: WiseCleanup.
Action ended 10:54:13: WiseCleanup. Return value 1.
Action ended 10:54:13: Fatal_Error. Return value 2.
Action ended 10:54:13: INSTALL. Return value 3.
Property(C): Action = wfdsdfdsfdsfdsf0
Property(C): DiskPrompt = [ProductName] [1]
Property(C): UpgradeCode = {6030C092-9D7D-4109-9897-E513BB71F9DF}
Property(C): InstallMode = Complete
Property(C): ProductCode = {FF15534E-277C-45F3-8EA5-F97BDB9F41C8}
Property(C): ProductName = Flowcode for PICmicros
Property(C): ProductVersion = 1.4.9
Property(C): Manufacturer = Matrix Multimedia Ltd.
Property(C): ReinstallFileOlderVersion = o
Property(C): ReinstallRepair = r
Property(C): ErrorDialog = ErrorDialog
Property(C): Accept = No
Property(C): INSTPPP = 0
Property(C): _WiseDebugMode = 0
Property(C): ProductID = none
Property(C): PPPINSTMAJOR = 3
Property(C): SecureCustomProperties = INSTALLDIR;REGISTER;INSTPPP;PPPPATH;UPGRADING
Property(C): Action5 = yuyu,uy,grnrwtgnwrtnrtnr0
Property(C): ApplicationUsers = AllUsers
Property(C): WiseInitAdminError = You must have administrator rights to run this installation. Please login as an administrator and re-run this installation.
Property(C): WiseEditorVersion = 7.3.0.259
Property(C): WiseInitSuffix = Wizard...
Property(C): PIDTemplate = ^^^^^^-^^^^^^-^^^^^^-^^^^^^-^^^^^^
Property(C): PPP_PATH = C:\Program Files\Matrix Multimedia\Common\PPPv3\
Property(C): Action4 = Flowcode V3 InstallThis installation is upgrading an older version of Flowcode V3. Once this installation has completed, you may need to "repair" the installation.
To do this, run this installation again and select the "repair" option.0
Property(C): ProductLanguage = 1033
Property(C): Action2 = Flowcode V3 InstallThis installation is upgrading an older version of Flowcode V3. Once this installation has completed, you may need to "repair" the installation.
Property(C): WiseInitPrefix = Initializing
Property(C): VALIDATED = 0
Property(C): MsiHiddenProperties = WISE_SQL_CONN_STR
Property(C): _WiseDialogTitleFontDefault = {&Arial8}
Property(C): _WiseDialogSuffix = Setup
Property(C): MaintenanceMode = Modify
Property(C): DefaultUIFont = Arial10
Property(C): WiseInitSpaceError = Could not create temporary file, not enough free temporary disk space. Please free up disk space and rerun this installation.
Property(C): PPPINSTMINOR = 9
Property(C): ReinstallFileVersion = o
Property(C): INSTALLDIR = C:\Program Files\Matrix Multimedia\Flowcode V3\
Property(C): PRIMARYFOLDER = INSTALLDIR
Property(C): WiseCRLF =
Property(C): INSTALLLEVEL = 3
Property(C): APPS_TEST = 1
Property(C): LICENCECODE = none
Property(C): REGISTER = UNREG
Property(C): _WiseDialogFontDefault = {&MSSansSerif8}
Property(C): ALLUSERS = 1
Property(C): PALMUSERS = 0
Property(C): WiseInitLangDefault = English,1033
Property(C): PPPMAJOR = 0
Property(C): WiseInitExistError = %s Version %s is already installed. You must uninstall the existing version before installing %s Version %s. Do you want to uninstall the existing version of %s?
Property(C): MxUpgrading = 0
Property(C): PPPver = 3.9.12.26
Property(C): SOURCEDIR = C:\Program Files\Common Files\Wise Installation Wizard\
Property(C): TARGETDIR = C:\
Property(C): Alarm = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\Alarm\
Property(C): Comps = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\
Property(C): ProgramFilesFolder = C:\Program Files\
Property(C): CommonFilesFolder = C:\Program Files\Common Files\
Property(C): SPI = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\SPI\
Property(C): WindowsFolder = C:\Windows\
Property(C): SystemFolder = C:\Windows\system32\
Property(C): TempFolder = C:\Users\Bernie\AppData\Local\Temp\
Property(C): GAC = C:\
Property(C): TCP_IP = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\TCP_IP\
Property(C): Components = C:\DEV\Flowcode2\Components\
Property(C): TCP_IP4 = C:\DEV\Flowcode2\Components\TCP_IP\
Property(C): INSTALLDIR1 = C:\Program Files\Matrix Multimedia\
Property(C): CAN = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\CAN\
Property(C): AddDefines = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\AddDefines\
Property(C): INSTALLDIR3 = C:\INSTALLDIR\
Property(C): Flowcode2 = C:\DEV\Flowcode2\
Property(C): Matrix_Multimedia = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Matrix Multimedia\
Property(C): Flowcode_V33 = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Matrix Multimedia\Flowcode V3\
Property(C): Common = C:\Program Files\Matrix Multimedia\Common\
Property(C): boostc = C:\Program Files\Matrix Multimedia\boostc\
Property(C): boostc5 = C:\Program Files\Matrix Multimedia\Flowcode V3\boostc\
Property(C): Buggy = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\Buggy\
Property(C): LocalAppDataFolder = C:\Users\Bernie\AppData\Local\
Property(C): PPPV3 = C:\Program Files\Matrix Multimedia\Common\PPPv3\
Property(C): Lib = C:\Program Files\Matrix Multimedia\Flowcode V3\boostc\Lib\
Property(C): include = C:\Program Files\Matrix Multimedia\boostc\include\
Property(C): include6 = C:\Program Files\Matrix Multimedia\Flowcode V3\boostc\include\
Property(C): config = C:\Program Files\Matrix Multimedia\Flowcode V3\boostc\config\
Property(C): fcd = C:\Program Files\Matrix Multimedia\Flowcode V3\fcd\
Property(C): components = C:\Program Files\Matrix Multimedia\Flowcode V3\components\
Property(C): ProfilesFolder = C:\Users\
Property(C): DesktopFolder = C:\Users\Public\Desktop\
Property(C): PrintHoodFolder = C:\Users\Bernie\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(C): Examples = C:\Program Files\Matrix Multimedia\Flowcode V3\Examples\
Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(C): CommonAppDataFolder = C:\ProgramData\
Property(C): INSTALLDIR2 = C:\DEV\
Property(C): EEPROM = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\EEPROM\
Property(C): FontsFolder = C:\Windows\Fonts\
Property(C): Keypad = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\Keypad\
Property(C): System16Folder = C:\Windows\system\
Property(C): RecentFolder = C:\Users\Bernie\AppData\Roaming\Microsoft\Windows\Recent\
Property(C): IrDA = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\IrDA\
Property(C): RS232 = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\RS232\
Property(C): NetHoodFolder = C:\Users\Bernie\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(C): Bluetooth3 = C:\DEV\Flowcode2\Components\Bluetooth\
Property(C): Internet = C:\DEV\Flowcode2\Components\Internet\
Property(C): WebServer = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\WebServer\
Property(C): Bluetooth = C:\Program Files\Matrix Multimedia\Flowcode V3\Comps\Bluetooth\
Property(C): WinSxS = C:\Windows\
Property(C): basic = C:\Program Files\Matrix Multimedia\Flowcode V3\boostc\include\basic\
Property(C): WWWROOT = C:\
Property(C): tools = C:\Program Files\Matrix Multimedia\Flowcode V3\tools\
Property(C): PICkit2 = C:\Program Files\Matrix Multimedia\Flowcode V3\tools\PICkit2\
Property(C): VersionNT = 600
Property(C): USERNAME = Bernie
Property(C): WiseCurrentWizard = Welcome_Dialog
Property(C): PPPMINOR = 0
Property(C): System.8C0C59A0_7DC8_11D2_B95D_006097C4DE24 = C:\Windows\system32\
Property(C): MS.8C0C59A0_7DC8_11D2_B95D_006097C4DE24 = C:\Windows\system32\
Property(C): Redist.8C0C59A0_7DC8_11D2_B95D_006097C4DE24 = C:\Windows\system32\
Property(C): Redist.1E64E430_36E0_11D2_A794_0060089A724B = C:\Windows\system32\
Property(C): MS.1E64E430_36E0_11D2_A794_0060089A724B = C:\Windows\system32\
Property(C): System.1E64E430_36E0_11D2_A794_0060089A724B = C:\Windows\system32\
Property(C): Redist.3207D1B0_80E5_11D2_B95D_006097C4DE24 = C:\Windows\system32\
Property(C): MS.3207D1B0_80E5_11D2_B95D_006097C4DE24 = C:\Windows\system32\
Property(C): System.3207D1B0_80E5_11D2_B95D_006097C4DE24 = C:\Windows\system32\
Property(C): Redist.3207D1B6_80E5_11D2_B95D_006097C4DE24 = C:\Windows\system32\
Property(C): MS.3207D1B6_80E5_11D2_B95D_006097C4DE24 = C:\Windows\system32\
Property(C): System.3207D1B6_80E5_11D2_B95D_006097C4DE24 = C:\Windows\system32\
Property(C): MsiLogFileLocation = c:\fc_log.txt
Property(C): PackageCode = {4549FEF9-D209-4BA6-826F-18AE33A2C0C1}
Property(C): ProductState = -1
Property(C): PackagecodeChanging = 1
Property(C): WISE_SETUP_EXE_PATH = E:\FlowcodeV3.exe
Property(C): CURRENTDIRECTORY = E:\
Property(C): CLIENTUILEVEL = 0
Property(C): CLIENTPROCESSID = 2160
Property(C): VersionDatabase = 200
Property(C): VersionMsi = 4.05
Property(C): WindowsBuild = 6000
Property(C): ServicePackLevel = 0
Property(C): ServicePackLevelMinor = 0
Property(C): MsiNTProductType = 1
Property(C): MsiNTSuitePersonal = 1
Property(C): WindowsVolume = C:\
Property(C): RemoteAdminTS = 1
Property(C): AppDataFolder = C:\Users\Bernie\AppData\Roaming\
Property(C): FavoritesFolder = C:\Users\Bernie\Favorites\
Property(C): PersonalFolder = C:\Users\Bernie\Documents\
Property(C): SendToFolder = C:\Users\Bernie\AppData\Roaming\Microsoft\Windows\SendTo\
Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(C): MyPicturesFolder = C:\Users\Bernie\Pictures\
Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(C): GPTSupport = 1
Property(C): OLEAdvtSupport = 1
Property(C): ShellAdvtSupport = 1
Property(C): Intel = 6
Property(C): PhysicalMemory = 2047
Property(C): VirtualMemory = 3218
Property(C): AdminUser = 1
Property(C): LogonUser = Bernie
Property(C): UserSID = S-1-5-21-2315786136-1225672124-3507104331-1000
Property(C): UserLanguageID = 2057
Property(C): ComputerName = STUDY
Property(C): SystemLanguageID = 2057
Property(C): ScreenX = 1920
Property(C): ScreenY = 1200
Property(C): CaptionHeight = 20
Property(C): BorderTop = 1
Property(C): BorderSide = 1
Property(C): TextHeight = 16
Property(C): TextInternalLeading = 3
Property(C): ColorBits = 32
Property(C): TTCSupport = 1
Property(C): Time = 10:54:13
Property(C): Date = 30/09/2008
Property(C): MsiNetAssemblySupport = 2.0.50727.3053
Property(C): MsiWin32AssemblySupport = 6.0.6000.16386
Property(C): RedirectedDllSupport = 2
Property(C): MsiRunningElevated = 1
Property(C): Privileged = 1
Property(C): DATABASE = C:\Users\Bernie\AppData\Local\Temp\cf821.msi
Property(C): OriginalDatabase = C:\Program Files\Common Files\Wise Installation Wizard\WISFF15534E277C45F38EA5F97BDB9F41C8_1_4_9.MSI
Property(C): SourceDir = C:\Program Files\Common Files\Wise Installation Wizard\
Property(C): VersionHandler = 4.05
Property(C): UILevel = 5
Property(C): ACTION = INSTALL
Property(C): EXECUTEACTION = INSTALL
Property(C): ROOTDRIVE = C:\
Property(C): CostingComplete = 1
Property(C): OutOfDiskSpace = 0
Property(C): OutOfNoRbDiskSpace = 0
Property(C): PrimaryVolumeSpaceAvailable = 508564048
Property(C): PrimaryVolumeSpaceRequired = 334604
Property(C): PrimaryVolumeSpaceRemaining = 508229444
Property(C): PrimaryVolumePath = C:
=== Logging stopped: 30/09/2008 10:54:13 ===
MSI (c) (70:7C) [10:54:13:348]: Product: Flowcode for PICmicros -- Installation operation failed.
MSI (c) (70:7C) [10:54:13:349]: Windows Installer installed the product. Product Name: Flowcode for PICmicros. Product Version: 1.4.9. Product Language: 1033. Installation success or error status: 1603.
Startup: Icon
Startup: Complete
Startup: Custom
Startup: New
Startup: Up
Startup: side16
Startup: top16
Startup: trash1
Startup: Music
Startup: Typical
Startup: CD
Startup: Info
Startup: Callpppv3
Signature: AppReg3
Signature: AppReg1
Signature: AppReg2
Signature: AppReg
- Steve
Re: VISTA ISSUE
I've got a few suggestions:
1) right-click the installer exe and select "run as administrator".
2) Make sure no other applications, including utilities such as virus scanners, are running in the background. Close all running applications and utilities, and launch the installation again.
3) Re-register VBScript.dll - see the final entry in this post:
http://forums.techsmith.com/archive/ind ... -2415.html
4) There are some additional things to try on this page:
http://juice.altiris.com/article/2658/e ... stallation
If you get it to work, please reply to tell me which solution worked.
If none of these work, please edit the shortcut you have created and change " /log c:\fc_log.txt" to " /l*v c:\fc_log.txt" and post this up when you have run the exe - this will give us some more details on what is going wrong.
Re: VISTA ISSUE
I have flowcode up and running now
I could not use a system recovery so ended
up doing a complete clean installation it went on perfect after that.
The old system went completely unstable.
Re: VISTA ISSUE
I had a fatal error (no code) when installing Flowcode. Error appeared even after changing properties to Run as Administrator, and right clicking Run as Administrator.
I managed sort out problem by downloading and installing 'Windows Installer 4.5 Redistributable' from Microsoft:
http://www.microsoft.com/downloads/deta ... laylang=en
File I downloaded was: Windows6.0-KB942288-v2-x86.msu
As I have got windows 32 bit Vista.
After installing and rebooting PC, Flowcode installed OK.
I Believe the problem was caused by uninstalling a program which also removed one of VB dll that is vital to
Flowcode installation < pure guess work only!
By installing windows installer, missing file was replaced?
That or installer was corrupt?
Re: VISTA ISSUE
Thanks for that Medelec
I have added your finds to our FAQ area.
