C4PIC Exercise 1.1 Problems
DonFL
Post by DonFL »
I'm using a version 3 Dev board, and starting thru the C$PIC course.
Trying to run exercise 1.1, but cannot build the program as I get errors from interrupt.c:
 Building...
BoostC Optimizing C Compiler Version 6.57 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2006 Pavel Baranov
Copyright(C) 2004-2006 David Hobday
Licensed to C4PICs User under Single user Standard License for 1 node(s)
Limitations: PIC12,PIC16 max code size:4096 words, max RAM banks:Unlimited, Non commercial use only
interrupt.c
C:\Program Files\Matrix Multimedia\C4PICs16\SourceBoost\Samples\C\BoostC\interrupt.c(22:25): error: unknown identifier 'T0IF'
C:\Program Files\Matrix Multimedia\C4PICs16\SourceBoost\Samples\C\BoostC\interrupt.c(22:25): error: invalid operand 'T0IF'
C:\Program Files\Matrix Multimedia\C4PICs16\SourceBoost\Samples\C\BoostC\interrupt.c(22:20): error: failed to generate expression
C:\Program Files\Matrix Multimedia\C4PICs16\SourceBoost\Samples\C\BoostC\interrupt.c(22:16): error: invalid operand '~(1 << ( T0IF ))'
C:\Program Files\Matrix Multimedia\C4PICs16\SourceBoost\Samples\C\BoostC\interrupt.c(22:13): error: failed to generate expression
C:\Program Files\Matrix Multimedia\C4PICs16\SourceBoost\Samples\C\BoostC\interrupt.c(46:24): error: unknown identifier 'T0IE'
C:\Program Files\Matrix Multimedia\C4PICs16\SourceBoost\Samples\C\BoostC\interrupt.c(46:24): error: invalid operand 'T0IE'
C:\Program Files\Matrix Multimedia\C4PICs16\SourceBoost\Samples\C\BoostC\interrupt.c(46:19): error: failed to generate expression
C:\Program Files\Matrix Multimedia\C4PICs16\SourceBoost\Samples\C\BoostC\interrupt.c(46:19): error: invalid operand '<<'
C:\Program Files\Matrix Multimedia\C4PICs16\SourceBoost\Samples\C\BoostC\interrupt.c(46:13): error: failed to generate expression
failure
"C:\Program Files\Matrix Multimedia\C4PICs16\sourceboost\boostc.pic16.exe" interrupt.c -t PIC16F88
Exit code was 1.
Removing target: interrupt.obj
Done
I did some searching within the foum, but could not decipher the fix a it was described. Can't find anything in any of the documentation to help me understand this one. I'm using the 1688 supplied with the board.
Any help to get me moving in the right direction is appreciated.
Re: C4PIC Exercise 1.1 Problems
My exercise 1.1 looks like this
/*  EX1.1 Light a LED      */
/*  David Miles April 2006 */
#include <system.h>
/* Set 8 MHz clock frequency */
#pragma CLOCK_FREQ 8000000
/* Set PIC16 configuration word */
#pragma DATA _CONFIG1, _EXTRC_CLKOUT & _WDT_OFF & _LVP_OFF
void main()
	trisa = 0xfe; /* set bit 0 of PORTA for output     */
	porta = 0x01; /* set bit 0 of PORTA to 1           */
Is this the same as yours? Interrupt.c should not be getting called by anything in the code. Have you included it somewhere in the IDE environment?
DonFL
Post by DonFL »
Whenever I open Sourceboost via the C4PIC icon, that is what opens up. That appears to be the issue. I'll see what I can do to close it, or prevent it opening.
I should get a clean IDE with nothing opened when I first open Sourceboost, right?
DonFL
Post by DonFL »
I see what I am doing wrong.
I was clicking on the SourceBoost icon, rather than the link for the exercise under the vpic.
