Hi guys, i wonder if you could direct me in the right direction, what i want to do is to input 3 PWM signal`s, as per radio control, into pic chip and read the length of the pulse to get a spread of `250 ish` then do my algorithms then output the resultant PWM`s back out to 3 servos. Taking account that i have setup a 18F2620 to produce PWM to servo`s, but it has used 2 clocks.
a few axamples i can think of,
Q. do i convert the PWM input to analogue and feed this to the 18F2620 (what would be the best way?).
Q. Can i use the existing 18F2620 PWM `controller` program and have enough resources to do it?.
Q. would it best to add another pic chip and output the result to the 18F2620 PWM `controller to do the PWM output side?.
Note that the existing PWM `controller` program is still needed as it is, with it`s analogue inputs. So the entire system hopefully would consist of 2 analogue sensors outputting to 2 servo`s, and an PWM signal
from 3 control channels being interrogated and the result output to another 3 servo`s.
So in your wisdom, what would you think the best method of attack would be in accomplishing my goal ?.
Thanks for any input you can give.
reading ppm/PWM signal into pic chip
Return to “General Programming”
Jump to
- Announcements
- ↳ Announcements
- The Knowledge Exchange
- ↳ Programming Tips & Tricks
- ↳ Freelance Embedded Engineers
- ↳ Article Discussion
- Microcontroller Programming
- ↳ General Programming
- ↳ Flowcode V9
- ↳ Flowcode V8
- ↳ Feature Requests
- ↳ Bug Reports
- ↳ User Components
- ↳ Flowcode V7
- ↳ User Components
- ↳ Feature requests
- ↳ Bug reports
- ↳ Fixed bugs
- ↳ 8-Bit PIC
- ↳ 16-Bit PIC
- ↳ 32-Bit PIC
- ↳ AVR & Arduino
- ↳ 32-Bit ARM
- ↳ Poll Discussion
- ↳ Flowcode V6
- ↳ Flowcode v6 Beta
- ↳ Bug reports
- ↳ Getting Started
- ↳ User Components
- ↳ Bug reports
- ↳ Flowcode V5
- ↳ Flowcode V5 Issues
- ↳ Flowcode V5 Suggestions
- ↳ Flowcode V5 Free Edition
- ↳ Flowcode V4
- ↳ Flowcode 4 Bugs
- ↳ Flowcode 4 Suggestions
- ↳ Flowcode V2 & V3
- ↳ General / Misc
- ↳ Components (Comms)
- ↳ Components (Other)
- ↳ Bugs / Application Errors
- ↳ Suggestions
- ↳ BTEC Unit 6
- ↳ C and ASM Programming
- ↳ E-blocks
- ↳ Formula AllCode
- ↳ Formula Flowcode
- ↳ MIAC
- Language Support Forums
- ↳ Deutsch Support-Forum
- ↳ Forums d'aide en français
- ↳ Foro de soporte español
- Other Matrix products
- ↳ Electronics products
- ↳ Matrix Online Courses
- ↳ Other products
- ↳ CoCo
- Hidden
