F886 -program memory is outside selected chip's memory range
Posted: Wed Oct 15, 2008 6:27 pm
by bidikar
I am new to Flowcode. I am using EB006-30-5 board to program PIC 16F886. When I compile the program to chip, I get a pop up "Hex file program memory is outside selected chip's memory range.". Also I see following errors during send of the code to chip. But my program seems to work FINE !!! (it's a simple to program to play with LEDs and LCS display. PGM is attached below).
-- snip --
Writing configuration memory
Writing id-locations
Reading program memory
Reading configuration memory
Finished reading PICmicro contents
Programming failed:
Program memory check failed
(NOTE: if the PIC is code-protected, this message will be
displayed even if the program has been sent correctly)
That took 43.984 seconds
Return code = 0
FINISHED
-- snip --
Program is attached.
Re: F886 -program memory is outside selected chip's memory range
Posted: Thu Oct 16, 2008 9:27 am
Please can you click on the Chip -> Configuration menu and then click switch to expert mode.
In here you will have to use the following settings to get your program onto the chip correctly.
