Programming PIC 18f6680
Forum for problems or queries regarding other Flowcode Components. Eg LEDs, Switches, LCD, Gfx LCD etc
mohandino
Has thanked: 1 time
Post by mohandino »
hello,
i buy a card with a PIC 18f6680 ( from modron** )
I wondered if i can use flowcode to program it ( probably to use a similar pic... )
Please help
Re: Programming PIC 18f6680
Im afraid that the 18F6680 is not currently supported by the current version of Flowcode. Good news is that it is possible to provide support for this fairly quickly. If you wish to go ahead and use Flowcode then let me know and I will generate the definitions to allow this chip to work.
mohandino
Has thanked: 1 time
Post by mohandino »
Benj wrote:Hello
I whant to make a big application with this PIC and i don't whant to learn the C language or others. Please generate the definition and tell me.
thanks
Is your 6680 using the 64 pin package or the 68 pin package?
mohandino
Has thanked: 1 time
Post by mohandino »
Benj wrote:Hello
It's normaly a 64 pins but i don"t receive the product yet. Is it hard for you to make the two PIC ?
thanks
Here is the 64 pin version of the definition file. Simply copy into your Flowcode v3/fcd folder and restart Flowcode. If it turns out that you need the 68 pin definition then let me know and I will generate that for you too.
18F6680.fcd
(8.92 KiB) Downloaded 338 times
mohandino
Has thanked: 1 time
Post by mohandino »
Benj wrote:Hello
Thanks a lot Benj
It's a PIC with 64 pins
