Pic 18F2420 PWM Disable
Dirk Bubley
Has thanked: 14 times
Been thanked: 12 times
Post by Dirk Bubley »
Hello together,
iΒ΄m working with the PWM generator at PIC 18F2420.
Everything is fine!! Starting and setting the PWM (Duty Cicle + Freqency) works.
....except PWM disable has no function. Once the PWM ist started you can`t turn it off again!!
Any ideas
BR
Dirk Bubley
:shock: ....i found the solution. You must set in PWM disable th nldx(byte) to 1.
This will shut down the PWM output. Unfortunatly the output stays high after switch off.
BR Dirk
