interrupt
Forum for problems or queries regarding the Flowcode application and compiler usage.
valvo
interrupt
Post by valvo »
Hi there I wonder if there may be a bug re interrupts ? I am trying to design a rev counter using a PIC 16F628 and need to clock timer0 from the tock pin (ra4) I have selected this option from the interrupt properties ie transition on tocki and interrupt on timer0 overflow but despite there being nothing clocking the ra4 pin I am still geting a call to the interrupt service routine regularly as if timer0 were being clocked by an internal source
I would add this is purely on simulation as I have as yet not tried to program a real chip
steve
Re: interrupt
The simulation of Timer0 will not work exactly as it would on the hardware. There should be no problems when running the code onboard a chip.
