Properties button on 1 LED component not visible
I created a component LED with numbers of LED 1. When it appears on the screen it is that small that the top line consists of the close (x) button, the minimize button (-) but the properties button (down arrow) has no space at the left and is not visible. How to change the properties in this case (as work around).
Re: Properties button on 1 LED component not visible
You may still just be able to click the properties for the LED by clicking right at the edge of the component. If not then you can always delete the LED component and create a new one.
