Is it possible to view the changes on variables and call stack when the program run?
When I go step to step is OK I can see the changes in the window but when I press "play" button to run the program then the call stack and variable windows are empty!
They only show if I hover my mouse over them!
Thank you
Regards.
variable-call stack window
Re: variable-call stack window
Change the clock speed setting for the simulation from run as fast as possible and set to say 100hz etc. This can be changed in the Chip -> Clock Speed menu. The variable and stack window should then be updated as your program is running.
