Flowcode is not representing 12f635 correctly, it only shows pins 0,1,2 but datasheet from microchip says 6 I/O pins.
Also, upon compiling a program, the compiler gives the following error:
coderencodersetup.c
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\pp.exe" "C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c" -i "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\include" -d _PIC12F635 -la -c2 -o coderencodersetup.pp -v -d _BOOSTC -d _PIC16
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(259:2): error: unknown identifier 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(259:2): error: invalid operand 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(259:9): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(260:2): error: unknown identifier 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(260:2): error: invalid operand 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(260:7): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(270:2): error: unknown identifier 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(270:2): error: invalid operand 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(270:9): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(271:2): error: unknown identifier 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(271:2): error: invalid operand 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(271:7): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(281:2): error: unknown identifier 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(281:2): error: invalid operand 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(281:9): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(282:2): error: unknown identifier 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(282:2): error: invalid operand 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(282:7): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(291:2): error: unknown identifier 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(291:2): error: invalid operand 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(291:9): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(292:17): error: unknown identifier 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(292:17): error: invalid operand 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(292:22): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(292:22): error: invalid operand '& '
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(292:30): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(292:30): error: invalid operand '=='
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(292:13): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(301:2): error: unknown identifier 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(301:2): error: invalid operand 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(301:9): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(302:2): error: unknown identifier 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(302:2): error: invalid operand 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(302:7): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(312:2): error: unknown identifier 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(312:2): error: invalid operand 'trisio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(312:9): error: failed to generate expression
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(313:2): error: unknown identifier 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(313:2): error: invalid operand 'gpio'
C:\Users\Damien\Desktop\FLOCODE\New Folder\coderencodersetup.c(313:7): error: failed to generate expression
coderencodersetup.c success
failure
Return code = 1
FINISHED
ANY VIEWS AS TO WHAT I AM DOING WRONG HERE? THERE IS NO C CODE IN MY PROGRAM.
THANKS
Compiler gives error for 12F635+Wrong representation
Re: Compiler gives error for 12F635+Wrong representation
The other 3 I/O on those 8 pin devices is consumed with the osciallator and reset pin. You can disable these options if you wish to use all of the I/O. Note that the reset pin can only be an input if you choose to disable the reset pin functionality.
Send me a copy of your program and I will take a look for you.
