Bonjour.
I search a custom FCD file for 18F2550 ans 18F4550 with bootloader Microchip : PICDEMO FS USB Board Firmware ( xtal 20 MHz ).
Thanks.
Bernard MAIROT
Custom FCd file for 18F2550 and 18F4550 with bootloader
calimero88
Re: Custom FCd file for 18F2550 and 18F4550 with bootloader
Bonjour.
This FCD file is taken from the USBpack and is designed for the Microchip FS USB Demo Board.
You should be able to see the edits from the original 18F4550 FCD file and then be able to copy the edits into your own custom FCD files.
The Microchip bootloader must be present on the target chip before programming will work correctly.
- MCHP_FSUSB.fcd
- (9.04 KiB) Downloaded 369 times
