ADC component connection
Forum for problems or queries regarding other Flowcode Components. Eg LEDs, Switches, LCD, Gfx LCD etc
boa279
Post by boa279 »
I might just be retarded but how is an ADC item actually connected. There is no schematic in the help files. Im going to use a POT as an example: im guessing 5 vdc is applied to the pot wiper and either end is applied to the pic depending on whether I want ascending or descending values...correct?? THANKS!!!
Re: ADC component connection
The ADC component is connected to an I/O pin that is labelled on the chip as ADC0 through to ADCn. To change the pin connection simply go into the components connection menu and change the pin as needed. Then all you have to do is perfom a sample and then read the value as an 8-bit byte or a 10-bit value.
To connect analogue devices to the I/O pin eg a pot simply connect the two ends of the pot to 5V and Ground and then connect the middle of the pot to the analogue I/O pin.
boa279
Post by boa279 »
Exactly what I was looking for...THANKS!!
