I have written a program with Flowcode V3 for a 40pin dil Pic16f887A. I would now like to use the 44pin TQFP package device and install the program on board using a MPLAB IDC2. The pinouts for this device are differant Can anyone tell me if the program will install itself into the new pin configuration? if not how do I go about making a template in flowcode for this device Thank you in advance
Pic16f887A
Re: Pic16f887A
The TQFP package will react just as the DIP package reacted so you do not have to do anthing here with FCD files etc. As long as your Port Pin connections are the same then you should have no problems. If you wish to make an FCD for the 44 pin package then you can do so by changing the following. Note that this is only superficial and will only affect the Flowcode simulation.
[Device] Section
Pins=44
DefaultPackageType=1
[Pins] Section
Rename as appropriate and add extra pins
[Ports] Section
Renumber PortPins as appropriate
Leave everything else as is.
[Device] Section
Pins=44
[Pins] Section
[Ports] Section
Re: Pic16f887A
Here is the 44-Pin TQFP FCD file. I have not tested it much but it seems to work ok. Let me know if theres any problems.
Simply drop the file into your Matrix Multimedia/Flowcode V3/FCD folder and restart Flowcode. You will then have the option for a 16F877A_TQFP in the target list.
- 16F877A_TQFP.fcd
- (7.82 KiB) Downloaded 271 times
Re: Pic16f887A
Thank you for the file
The FCD file simulates ok but will not compile to HEX. When entering the "chip configure" menu I get a report "Unrecognised chip on command line ". If I select "OK" and enter the "expert config screen" the device does not appear in the "select Chip" menu. If I select PIC16F887A I get a report "Configure data is differant" and options to use either of the pics. If I select PIC16F887A_tqfp and compile to hex I then get a error report (See attached) am I just being thick and missing something???
Best Regards
James
Best Regards
James
- test prog.msg.txt
- (10.72 KiB) Downloaded 240 times
Re: Pic16f887A
Sorry about that all working now. (hopefully)
Missed this line from the [Device] section.
ChipName=16f877a
ChipName=16f877a
- 16F877A_TQFP.fcd
- (7.83 KiB) Downloaded 248 times
