Need help SPI component.
I can write data but not read data with SPI interface. Matrixmutilmedia's supporter can help me an example SPI interface ???
Thank in advanced
Re: Need help SPI component.
Sure we can help. Here are a few quick questions to get started.
What are you interfacing to via SPI?
How do you know writes are working ok?
Do you have a demo program you are using that I could look at? (you can attach Flowcode programs to the forum if you need to)
Ok Benj.
I uses TC72 to measurement temperature. When power on, TC72's configure register is 05h. Then i write cnfigure word 04h to TC72 active. I uses Proteus VSM to simulation circuit. So i know i can write data to TC72 but i can't read temprature. please see picture attacth
Thank in advanced
Are you toggling the CS enable line as shown in page 5 of the datasheet.
http://ww1.microchip.com/downloads/en/D ... 21743a.pdf
Basically send the CS line high then perform the read and when you are finished send the CS line low again.
Ever have an example I2C EEprom on MM website
http://www.matrixmultimedia.com/Downloa ... .php?id=39
and then i do I2c very well. I sucessfuly to read time from DS1307 RTC with I2C protocol
I think MM'supporters have an example about SPI component. I will learn in these example.
Thank in advanced
