Error in USBSlave_code.c after update to v3.6.11.53
Forum for problems or queries regarding the Flowcode application and compiler usage.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
After updating Flowcode (for PIC) to 3.6.11.53 using the 3.4/3.5 updater code using the USB Slave component does not compile. The error is caused by a typo on line 375 of USBDlave_code.c, it reads '#els' and should be '#else'.
Best regards,
Jac
― C.S. Lewis
Re: Error in USBSlave_code.c after update to v3.6.11.53
Hi Jac,
Thanks very much for spotting this. I hope it did not cause you too much of a headache!
I'll make sure there is an FAQ put up about this.
Hello Jac
Sorry about this. I have now fixed all three sets of files to allow the components to work correctly. The problem only appears when the enumertaion wait setting is activated inside the USB component.
Details can be found here on our FAQ.
http://www.matrixmultimedia.com/support ... .php?t=548
